Go to Post Look at the success of the Banebot's gearboxes this year. Cheap, light, small, and a lot of people are using them, even though their quality may be a bit questionable... Make a similar gearbox for a drivetrain (with a bit more robustness) and I think you've got a winner. - Ben Piecuch [more]
Unread 17-02-2016, 16:21
2386programming 2386programming is offline
FRC #2386 (Trojans)
Rookie Year: 2011
2386programming is an unknown quantity at this point
Auto Selector
I am lost. I have put in the exact example code into my code for an autonomous selector, but in my autonomous.vi, when I connect the read string function to the case structure, all the case structure reads is true and false.
Unread 17-02-2016, 23:00
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Auto Selector
You should post your Autonomous Independent vi, so we can load it and see what might be giving you this problem.
