Go to Post It's more of a "gracious professionalism" thing. - Matt Leese [more]
Unread 17-02-2016, 18:59
DurT1178 DurT1178 is offline
FRC #1178
DurT1178 is an unknown quantity at this point
PCM Compressor Fault
Hello Everyone!
Our PCM is giving us a peculiar problem. It constantly switches between a compressor short and the sticky fault caused by that. It runs when the sticky fault is present. There is absolutely no visible short, and it has been rewired several times. We are using 18AWG wire going between our 16AWG compressor and the PCM because 16AWG doesn't fit. We have determined that it is not a compressor problem, nor is it a message that is a mix of red/orange, as it is too erratic of a change between them. Even the NI Configuration says it is a short. Could there be something wrong with our PCM?
Thanks in advance!
