G39 - Autonomus
How many robots will get G39 fouls during Autonomous?
I'll have to tell the programmers to check their position, and do not shoot if not in the right place. |
Re: G39 - Autonomus
That being said, I think a lot of teams will get stuck on defences, or read their position inaccurately, during autonomous. However, some teams may have a way to mitigate this ![]() |
Re: G39 - Autonomus
I do not foresee this being an issue with my team, but I do think this will be fairly common and something to keep track of when scouting.
Re: G39 - Autonomus
If a team can't use that to tell the difference between being flat on the floor or sitting on a defense before firing... I will be very sad. I might even go around at events making sure every team that plans on shooting, that our team would play with in quals at least, can utilize that feature to ensure no fouls. Last edited by JohnFogarty : 18-02-2016 at 01:16. Reason: Poor spelling. |
Re: G39 - Autonomus
Even if a team decides to implement this, they still have to reorient to face the goal and shoot, for which they need to determine their distance and angle to the goal. If their vision is capable of this, it negates the need for a gyro in the first place. |
Re: G39 - Autonomus
Re: G39 - Autonomus
It's not quite this simple to tell if you are stuck on a defense though. Teams can still be trapped on defenses when their robots are parallel to the floor. This will be very common on the moat, and could still happen with many other defenses.
Re: G39 - Autonomus
In that case, one could monitor the current going to the drive motors... if the drive wheels are spinning free they're not in contact with the carpet.
Re: G39 - Autonomus
We're mounting color sensors to the underbelly of our robot. We'll be watching for green, then not green, then green again.
#10
Re: G39 - Autonomus
I don't necessarily see the accelerometer as a viable option for getting reliable data in autonomous unless you plan on only crossing defenses with level surfaces (unlike the moat or rough terrain). Otherwise, you will find that the inaccuracy of the accelerometer will hinder your tracking of positions on the field.
#11
Re: G39 - Autonomus
Re: G39 - Autonomus
... another check before firing. ... another check most teams won't do ![]() As the OP stated, there will be a number of G39s during autonomous. |
#13
Re: G39 - Autonomus
Humm...
Forgot about the built in roborio... Nothing but Navx... #Pudding https://youtu.be/l1z8WqELviA |
#14
Re: G39 - Autonomus
We have developed a great way to tell if we made it to the other side of the outer works so we don't rely on encoders. Hint: The outerworks are a lot shinier than the carpet.
#15
Re: G39 - Autonomus
If you are lined up with the goal, then I'd risk taking the shot. We have a NavX, so hopefully we can get some useful data from that. |
