Robot project doesn't load on new laptop
I have copied the robot project to a usb flash drive but the project doesnt open on my new laptop.
I double click the project and it just opens LabVIEW but not the project, I have also tried to use File>Open but it didn't work either. How can I fix this? Thanks. |
Re: Robot project doesn't load on new laptop
Did you only copy the .lvproj file? If so that is not everything you need. If not could you show a screen shot of what you did copy to your computer?
Did you install the FRC update? How big was the file that you copied over? |
How big was the whole directory under documents/LabVIEW Data that you needed to copy?
The problem was solved!
I should have used File>Save as>Duplicate in order to "move" the project to the USB flash drive in order for it to work properly. |
I'm having the same problem.
I used duplicate, but it still doesn't work. I tried all of the above. The project was developed on one computer but it cant be opened on two other computers. How can I fix this? |
The fix depends on what the problem is. How did you copy the project? How are you trying to open it? What exactly happens when you try?
Then I plugged the USD flash drive in a different computer and tried opening the project from the Getting started window -> open. Didn't work. Then I tried opening the .lvproj file. Didn't work. All it does is open the getting started window. I tried all of the above on another computer. Didn't work, same problem. The three computers have FRC 2016 Labview software (Labview 2015 for FRC 2016). Last edited by Amitai : 12-03-2016 at 18:24. |
Any ideas?
Is the USB drive letter the same on the source and destination computers?
#10
What files are currently on the USB drive?
