Bandsaw blade suggestion Metal AND Wood
Our VEX teams have access to a shop that has a little used 14" bandsaw. The owner is willing to install a donated blade on it, but he needs the ability to cut up to 3/4" plywood.
So I'm looking for a compromise blade that will cut the softer steel of VEX metal, aluminum, polycarb plastic AND cut 3/4" plywood. I know that it's not going to be the best in both worlds, but would like to hit the mid-point. Because of the small VEX pieces being able to cut a smaller radius would be a bonus. I'm looking at carbon steel with a skip tooth pattern to help with clearing the wood chips, but I'm a little out of my depth. Thanks! Saw information Jet JWBS-14DXPRO, 14" Deluxe Pro Bandsaw Kit Band Saw Size/Wheel Diameter (In.) 14 Cutting Capacity Width (In.) 13-1/2 Cutting Capacity Height (In.) 12 Blade Length (In.) 105 Blade Speed (SFPM) 1500/3000 Last edited by Foster : 19-02-2016 at 12:25. Reason: Updated to add specs |
Re: Bandsaw blade suggestion Metal AND Wood
Use something else to cut steel, and us the finest blade he can get away with for the thicker plywood.
Yep, 1500 sfm is about 8-10x too fast to cut steel, regardless of blade choice.
Alrighty then, that was easy! Thanks!
We don't run into a lot of scenarios for cutting steel that aren't amenable to the hacksaw or the Dremel. We switched to EZ Lock cutoff wheels on the Dremel and really like them.
I watched a roboteer use one of them and then drop it. The bounce was pretty amazing. No injuries, but it ended my allowing them to use Dremel tools.
I have no use for a Dremel tool on anything I work on. Maybe I have too many 4.5" and 7" and 8" angle grinders!
but at school, we use a hacksaw and vise to cut steel. At home, I use an abrasive chop saw, or a cutting torch, or a 3" air powered cutoff wheel. When we made a steel frame at school, I brought in my chop saw. If I were serious about cutting steel, I'd get a good sized horizontal band saw for cutting stock, and a plasma cutter for cutting sheets. But I'm too cheap. |
We cut VEX metal with a hack saw now, I was just entranced by the ability to get to a bandsaw to cut metal.
Angle grinders fall into the same category of Dremel. Drop them and it spins on the ground. Hard to drop a band saw. Quote:
There are small "convertible" horizontal bandsaws that run at the right speed to cut steel, and can be set in a vertical position.
http://www.harborfreight.com/horizon...saw-93762.html I have used one years ago, it would probably be OK for light metal like you are planning to use it with, but not so good for heavy stuff I work on at home. |
