Go to Post Sally Ride says role models are needed - that's you. - JaneYoung [more]
Unread 19-02-2016, 14:46
gofmannir gofmannir is offline
AKA: Nir Gofman
FRC #2096 (RoboActive)
Rookie Year: 2015
gofmannir is an unknown quantity at this point
How to do automatic action in the teleop?
Hello
I'm trying to implement that when I'm press a button on the joystick the robot starting an automatic actions (in the teleop periodic)...
for example when pressing a button 3 it will called a custom method:
Code:
if(stick.getRawButton(3)){
     startAutoMoving();
But I'm still want the all the other statements and the other action still will work - which means the I cant use here the delay() method...
Any ideas?
Unread 19-02-2016, 17:07
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: How to do automatic action in the teleop?
Sure. Your autonomous action should be implemented using a state machine. The state machine should have a START state and a DONE state. In your teleop periodic, you check for a button and then start the state machine. You also add a statement to execute the state machine in your teleop periodic code. Something like this (this is pseudocode so it is not syntactically correct):
Code:
private int autoActionState = 0;  // 0 is the DONE state.
private void runAutoAction()
    switch (autoActionState)
        case 1:
            // do step 1
            break;
        case 2:
            // do step 2
            break;
        default:
        case 0:
            // We are done, don't do anything.
            break;
public void teleOp_Periodic()
    if (button 1 is pressed)
        // Start the state machine.
        autoActionState = 1;
    // doing other things.
    runAutoAction();
