Go to Post FIRST doesn't graduate you from HS ... your performance in class (your grades) do. - Franchesca [more]
Unread 19-02-2016, 16:23
JohnM's Avatar
JohnM JohnM is offline
FRC #5854 (Glitch)
Rookie Year: 2013
JohnM has a spectacular aura aboutJohnM has a spectacular aura about
Expanding the ethernet ports on router?
I'm looking for way to easily expanding the ports on the new router. I was wondering what specific products you guys have used so I can get an idea of what works and doesn't work. We plan on plugging in a Raspberry Pi and Axis Camera into the this network switch.
Unread 19-02-2016, 17:03
techhelpbb's Avatar
techhelpbb techhelpbb is offline
FRC #0011 (MORT - Team 11)
Rookie Year: 1997
techhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond repute
Re: Expanding the ethernet ports on router?
As recommended in another topic:
TRENDnet 5-Port Unmanaged Gigabit Switch TEG-S5g
Requires 5VDC at 1A.
Was a little dubious if there would be rules issues with this but at this time no one has voiced a dissenting opinion that this breaks any rules.
Unread 19-02-2016, 19:25
Jalerre's Avatar
Jalerre Jalerre is offline
FRC #4965 (FIRE)
Rookie Year: 2013
Jalerre is on a distinguished road
It is possible to use the old D-Link router to get more Ethernet ports as long as the wireless is disabled.
Vex
2013: 415 - Fabrication, Programming, Electrical
2014: 415D - Captain, Programming Lead
FTC
2014: 7354 - Programming Lead
FRC
2013: 415 - Safety Animation, Fabrication
2014-2015: 4965 - Programming & Electrical
2016: 4965 - Captain, Programming Lead, Electrical
Unread 19-02-2016, 20:03
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
Yes. See team update 11 to r57
Unread 19-02-2016, 21:12
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
It is possible to use the old D-Link router...
...assuming this isn't your first year in FRC and you actually have a D-Link to use.
