Go to Post ...the hardest part of engineering is communication. - EricVanWyk [more]
Unread 19-02-2016, 19:25
thblackhelmetma's Avatar
thblackhelmetma thblackhelmetma is offline
AKA: Aleksandar Antic
FRC #0670 (Homestead Robotics Team)
Team Role: CAD
Rookie Year: 2015
thblackhelmetma is an unknown quantity at this point
Question JavaCV Help
Hello fine members of Chief Delphi!
Team 670 is trying to use OpenCV for vision tracking of the goals, and for various reasons, we exclusively code in Java. Therefore, we are using JavaCV in order to do our tracking.
Our algorithm works fine when we use images and run it directly on our PC. However, when we upload the code to the roboRIO, we get an UnsatisfiedLinkError (Stack Trace Below). This error pops up whenever we call any method from any class in the OpenCV package.
Code:
ERROR Unhandled exception: java.lang.UnsatisfiedLinkError: no jniopencv_core in java.library.path at
[java.lang.ClassLoader.loadLibrary(ClassLoader.java:1857),
java.lang.Runtime.loadLibrary0(Runtime.java:870),
java.lang.System.loadLibrary(System.java:1119),
org.bytedeco.javacpp.Loader.loadLibrary(Loader.java:597),
org.bytedeco.javacpp.Loader.load(Loader.java:438),
org.bytedeco.javacpp.Loader.load(Loader.java:381),
org.bytedeco.javacpp.opencv_core.<clinit>(opencv_core.java:10),
java.lang.Class.forName0(Native Method),
java.lang.Class.forName(Class.java:340),
org.bytedeco.javacpp.Loader.load(Loader.java:413),
org.bytedeco.javacpp.opencv_imgcodecs.<clinit>(opencv_imgcodecs.java:13),
org.usfirst.frc.team670.robot.Robot.process(Robot.java:85),
org.usfirst.frc.team670.robot.Robot.operatorControl(Robot.java:68),
edu.wpi.first.wpilibj.SampleRobot.startCompetition(SampleRobot.java:159),
edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:242)]
WARNING: Robots don't quit!
I have verified our build.properties and build.xml files many times, and they appear to be correct, but I will include them here anyway.
build.properties
Code:
# Project specific information
package=org.usfirst.frc.team670.robot
robot.class=${package}.Robot
userLibs = ${user.home}/wpilib/user/lib/javacpp.jar:${user.home}/wpilib/user/lib/opencv.jar:${user.home}/wpilib/user/lib/javacv.jar
build.xml
Code:
<project name="FRC Deployment" default="deploy">
    <property file="${user.home}/wpilib/wpilib.properties"/>
    <property file="build.properties"/>
    <property file="${user.home}/wpilib/java/${version}/ant/build.properties"/>
    <property name="classpath" value="${opencv.jar}:${javacpp.jar}:${javacv.jar}" />
    <import file="${wpilib.ant.dir}/build.xml"/>
</project>
So far, I have tried adding various native libraries to all of the different jars, in order to try and appease the UnsatisfiedLinkError, adding various dll files, and many other solutions recommended by the Internet. Nothing has worked thus far.
Could anyone help with this problem?
