Go to Post If only 5% of American entry level workers are proficient in algebra in 2022, I'm moving to Canada. - PVCpirate [more]
Unread 19-02-2016, 20:07
Beta+ Beta+ is offline
FRC #2130 (Alpha+)
Rookie Year: 2015
Beta+ is an unknown quantity at this point
Hanging bar dimensions
We're having a heck of a time finding the dimensions for the hanging bar for the end game. Our mock up - following the drawings for the practice hanging rung and the tower ended up with ~ 1" gap from the 45 degree angle from the goal.
It looks - after looking at the drawings for the practice tower, the practice hanging wall, and the actual field drawings - that they're all different. To cap it off, the piping height on the actual field drawings has to be derived from 3 separate pages.
Our hanging design is critical to the specific gap and angle between the tower wall, the rung, the overhang, and the height above the batter. Does someone with access to a regulation field have these measurements or can someone direct me to what we're missing?
Thanks so much!
Unread 20-02-2016, 00:49
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: Hanging bar dimensions
The field drawings (not the team plans or rules) are the most authoritative. That said, you should not expect the field to necessarily exactly match any one of these plans.
Originally Posted by Game Rules, page 2
The competition ARENA is modular and assembled, used, disassembled, and shipped many times during the competition season. It will undergo wear and tear. The ARENA is designed to withstand rigorous play and frequent shipping. Every effort is made to ensure that ARENAS are consistent from event to event. However, ARENAS are assembled in different venues by different event staff and some small variations occur. For details regarding assembly tolerances, please refer to the 2016 ARENA Layout and Marking Drawing. Successful Teams will design ROBOTS that are insensitive to these variations.
It is not uncommon for the differences between the field drawings and the actual fields to significantly exceed the field drawing tolerances. In Ultimate Ascent, the frisbee feeders were about an inch and a half too low, and the first rung of the pyramid rather high (we weren't sensitive to that one, so I don't know by how much). Design so that the errors don't matter, or at least so that you can make adjustments at the event. IIRC, there is an opportunity to measure critical field dimensions on the first day of each event. If this matters, take advantage of it. Here it is, between rules T26 and T26A:
5.5.8 Measurement
The ARENA will be open for at least 30 minutes prior to the start of Qualification MATCHES, during which time Teams may survey and/or measure the FIELD, and bring ROBOTS on the FIELD to perform sensor calibration. During this time ROBOTS can be enabled, but can not move, nor can they interact (e.g. shoot, push, pickup, etc.) with BOULDERS or DEFENSES. The specific time that the FIELD is open will be communicated to Teams at the event. Teams may bring specific questions or comments to the FTA.
