Go to Post We also had a couple of student leaders emerge from this offseason Rumble, which can do nothing but help the team in the upcoming FRC season. - JesseK [more]
Unread 19-02-2016, 22:37
Caboose's Avatar
Caboose Caboose is offline
Programmer - LabVIEW, C++, C#, Java
AKA: James Parks
FRC #0900 (Zebracorns)
Caboose has a spectacular aura aboutCaboose has a spectacular aura about
Question Help with Armabot RS7 Talon SRX Feed-Forward Tuning
Hoping someone could help with this...
Using CTRE math in the `Speed Closed Loop.lvproj` to calculate the F value of a Armabot RS7 encoder with 12CPR on a 775pro, we are having an issue with the produced F value being too small to run the motor at the desired value.
CTRE Code.
Code:
VelocityNativeUnits = Change In Sensor / 100mS
also
VelocityNativeUnits = RPM / 600 * SensorUnitsPerRotation
Fgain = 100% X 1023 / VelocityNativeUnits ,
       where VelocityNativeUnits  is measured at 100% throttle
Mag Encoder has 4096 units per rotation.
Example: VelocityRPM is 10198 at 100% throttle
                 => VelocityNativeUnits = (10198 / 600 * 4096) = 69618
                 => Fgain = (1023 / 69618)  = 0.01469
We are setting the CPR using the Talon SRX API VI. And multiply the CPR by 4 to get the SensorUnitsPerRotation.
Since the CPR is being set the `Sensor Velocity` is returned as RPM. So to get the VelocityNativeUnits we use the second equation.
Running the motor in %vbus at 10% we get a VelocityNativeUnit of 31 so we use the equation Fgain = (1023 * 0.1) / 31 = 3.3. Trying to run this Speed mode this applies a throttle of 1%.
Am I doing something obviously wrong?
navX Labview Library
"Robots are aluminum shavings, held together by zip-ties."
myManga
Unread 20-02-2016, 16:27
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Re: Armabot RS7 Talon SRX Feed-Forward Tuning
Use the self-test to confirm the native velocity as seen by the Talon.
Also I would avoid using the config-encoder-cpr VI and use native units in your LV app, see section 21.25 for the details
Unread 20-02-2016, 17:51
Caboose's Avatar
AKA: James Parks
This seems to work, thanks.
myManga
Unread 21-02-2016, 10:09
We were bitten by the div by four sensor feature. It didn't cause issues with our F calculation, but we noticed it and thought is was rollover.
I've been meaning to ask you why that feature exists in the LV version. Do we need these things exposed?
Greg McKaskle
