Go to Post "In PID, Integrals are like diamonds. They are forever!" - Sam390250 [more]
Unread 20-02-2016, 16:39
Tiago_MARS Tiago_MARS is offline
Mechanical Lead
FRC #1523 (Mega Awesome Robotic Systems)
Team Role: Mechanical
Rookie Year: 2014
Tiago_MARS is an unknown quantity at this point
Router browns out with multiple CIMS driving WCD
We have a 6 CIM West coast drive, and whenever we try to turn the router browns out. We tried dropping to 4 CIMS and it still happened. 2 CIMS worked, and we tried rotating out the motors so that wasn't the problem. If you turn the robot by hand it also turns easily and it doesn't appear to be a problem with the gearboxes. Each motor is pulling approximately 40-45 amps when in max load and we don't believe that would be normal in this type of drivetrain. Has anybody experienced this before?
Unread 20-02-2016, 16:43
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Router browns out with multiple CIMS driving WCD
What kind of wheels?
What's the wheelbase and trackwidth?
How far did you drop the center wheels?
What's your gear ratio?
Put it up on blocks and tell us how much current it draws.
Unread 20-02-2016, 16:44
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Did you look at the Driver log file to see how low the voltage was pulled?
Unread 20-02-2016, 17:07
Mechanical Lead
Rookie Year: 2014
We're using the AndyMark 8" pneumatic wheels
It's a 6 wheel drive. The wheels are 12.5" apart.
The center wheels are dropped 1/8".
Not sure about the ratio but it's the 2.06 spread for the 3 CIM WCD from West Coast Products. With an 11 pinion input.
It's pulling 10 amps on the blocks, but if you reverse directions it goes over 50
Also, when it drops out the voltage drops under 9.
Unread 20-02-2016, 17:20
Ether's Avatar
Rookie Year: 1969
We're using the AndyMark 8" pneumatic wheels... The center wheels are dropped 1/8"..
1/8" may not be enough for pneumatic wheels.
Full throttle?
The numbers are ambiguous and seemingly inconsistent:
10 amps total divided by 6 motors would be only 1.7 amps per CIM, which is less than their free amps.
50 amps per motor times 6 motors would be 300 amps, which would pop your main breaker.
Please elaborate.
Unread 20-02-2016, 17:26
Just Itinerant
The robot radio shouldn't brownout until ~4.5v if it's wired to the VRM.
Unread 20-02-2016, 17:35
Mechanical Lead
Rookie Year: 2014
Full throttle?
Please elaborate.
Yes that was all per motor, but only 4 motors are on right now. It was also full throttle. However the 50 amps were only a spike as we reversed direction so the breaker didn't pop because it was instantaneous.
Also we thought about the 1/8" not being enough but it has worked previously, we are only experiencing this today. Also its pulling these amps on the blocks so the wheel drop shouldn't affect the amps right now...
Unread 20-02-2016, 17:47
Ether's Avatar
Rookie Year: 1969
Can someone please comment:
For a 4 CIM West Coast drive, is 10 amps per CIM par for the course for full throttle up on blocks?
How about 1/8" center drop for 8" pneumatic wheels?
Unread 20-02-2016, 18:14
Chris Mounts's Avatar
Chris Mounts Chris Mounts is offline
FRC #1188 (Oaktown Crewz)
Team Role: Coach
Rookie Year: 2010
Chris Mounts is an unknown quantity at this point
We're running a similar setup. We've got the 8" pneumatic wheels, WCD gear boxes with the same gear ratio (I think), 3 CIMs each side, and a 1/8" drop. The only difference is our C/C of wheels is about 7.9". We're driving and turning without an issue. I'm sure the larger C/C distance isn't helping but I wouldn't think it would cause consistent brown outs though.
Can you compress the C/C distance?
Not sure about the current. Never checked on blocks.
Unread 20-02-2016, 18:31
Bob Steele's Avatar
Bob Steele Bob Steele is offline
On the RIBMEATS bandwagon....
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
We are using 8 6" pneumatic wheels and 6 CIMs and are using a 3/16" drop this year because of the pneumatic wheels.
You might also take a look at what pressure you are using in your tires.
Higher pressures would probably help with scrubbing.
We are also current limiting in the program to maintain voltage to the RoboRio.
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
Unread 20-02-2016, 19:16
Mechanical Lead
Rookie Year: 2014
Well we found out through the VRM that it is in fact not the radio but the RoboRIO that is browning out. There isn't a very easy way to change the drop or the C/C without redoing the entire chassis and I don't think that would be necessary since it had already worked earlier in the week.
Unread 20-02-2016, 19:22
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
We've been running 3/16 and a high difference in pressure between the center and outer wheels and we have been pretty good. One of these changes is easy and the other probably is not.
Unread 20-02-2016, 19:23
Ether's Avatar
Rookie Year: 1969
difference in what direction?
Unread 20-02-2016, 19:54
Chris Hapstack's Avatar
Chris Hapstack Chris Hapstack is offline
Design Mentor
FRC #0342 (Burning Magnetos)
Rookie Year: 2007
Chris Hapstack is a jewel in the roughChris Hapstack is a jewel in the roughChris Hapstack is a jewel in the rough
I think the trend has been over-inflating the center wheels and under-inflating the front & back wheels, which kind of adds to the drop center effect. But of course I can't answer for 422.
  #15   Spotlight this post!
Unread 20-02-2016, 20:51
Oblarg Oblarg is offline
AKA: Eli Barnett
FRC #0449 (The Blair Robot Project)
Oblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond repute
With a non-traction-limited 6CIM drive, I can verify that this can (and does) happen reversing direction without a voltage ramp.
"Mmmmm, chain grease and aluminum shavings..."
"The breakfast of champions!"
Member, FRC Team 449: 2007-2010
Drive Mechanics Lead, FRC Team 449: 2009-2010
Alumnus/Technical Mentor, FRC Team 449: 2010-Present
Lead Technical Mentor, FRC Team 4464: 2012-2015
Technical Mentor, FRC Team 5830: 2015-2016
