Go to Post Yes, it can. You'll have to ask the lawyers around here whether it's legal or not. - Kevin Watson [more]
Unread 20-02-2016, 20:27
emvela5814 emvela5814 is offline
AKA: Edgar
FRC #5814 (ROBOTA)
Rookie Year: 2016
emvela5814 is an unknown quantity at this point
ERROR -44003
Hi. I'm new to FRC.
My team is 5814 and we are from Ecuador.
I've set up the bridge to 10.58.14.1 and the AXIS camera is on 10.58.14.16 by DHCP. Laptop is on wifi to the bridge.
I've got this when running the default Robotmain.vi
ERROR -44003 FRC: Operation failed due to a communication failure with the camera. WPI_CameraIssue HTTP Request with Authentication.vi
On Vision Processing.vi, the Select block is set on False cause I'm ussing IP camera.
I want to see the IP camera streamming on dashboard but I can't
Please Help
Unread 20-02-2016, 20:34
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: ERROR -44003
The default Dashboard is looking for an IP camera with the mDNS name of "axis-camera"
To set that up you need to browse to the camera, find the TCP/IP advance settings and give it that name.
Unread 20-02-2016, 22:57
AKA: Edgar
FRC #5814 (ROBOTA)
Rookie Year: 2016
Re: ERROR -44003
I have done what you said, but still the problem.
ID:	20132  Click image for larger version
Unread 21-02-2016, 10:14
Greg McKaskle Greg McKaskle is online now
Re: ERROR -44003
The Axis camera implements client authentication. If you use the config tool, it will create an account called FRC with a password of FRC. You can also do this by hand in the web config. I believe it may also work if you turn on the checkbox of anonymous access. But I don't think anonymous viewers are allowed to set certain properties, so the FRC/FRC approach is recommended.
Greg McKaskle
Unread 21-02-2016, 10:43
AKA: Edgar
FRC #5814 (ROBOTA)
Rookie Year: 2016
Re: ERROR -44003
I have set the User and Password on the cametra as you said.
I have also configured camera's IP on vision processing and on dashboard and deployed.
When running the robot main, I select IP Camera on dashboard and NT Connection indicator turns green.
Dashboard does'n return any problem but image is still not showing.
Any other suggestion?
ID:	20136  Click image for larger version
ID:	20137  Click image for larger version
Unread 22-02-2016, 08:01
Re: ERROR -44003
To help with debugging, please open a web browser and enter axis-camera.local as the URL to see if this is the device name of the camera and to see that the name is resolved. Your diagrams look correct, so it seems like the camera configuration is not quite there.
The camera pages are not the same for different cameras, but there is an advanced TCP page where you can set the device name. It is sometimes set to axis-#######, using the serial number for the digits. See if you can find the camera name in the advanced tab and change it.
Greg McKaskle
Unread 22-02-2016, 09:35
Just Itinerant
Re: ERROR -44003
Change the name you hardcoded in Dashboard Main from axis-camera.local to axis-camera.lan
