Go to Post Great. Just what we need. DHS showing up at all the regional competitions. . - dlavery [more]
Unread 21-02-2016, 01:09
kitare102 kitare102 is offline
AKA: Eric
FRC #3042 (Cobalt Catalysts)
Team Role: Mechanical
Rookie Year: 2013
kitare102 is an unknown quantity at this point
Fixing Slop of Gear on Hex Shaft
Our shooting mechanism rotates up and down on a hex shaft driven by a hex gear on the shaft. Picture here: http://imgur.com/S4qvkzd. While having a good amount of slop between shaft and gear is alright for gearboxes, it makes our design difficult, as the arm can rotate by a few degrees without moving the gear. This presents a problem when using a PID loop to control the angle, as getting to the position quickly or driving while maintaining the angle causes the arm to bounce up and down fairly rapidly. We've tuned the PID loop such that the effect isn't terrible, the there are still ranges in the motion of the arm that bounce a lot. Does anyone have an idea as to what we could do to the gear or the shaft that would (robustly) remove the slop between the two? Tell me if any more specific information would help.
Unread 21-02-2016, 01:15
EricH's Avatar
EricH EricH is online now
New year, new team
FRC #1197 (Torbots)
Re: Fixing Slop of Gear on Hex Shaft
I would use a shim between the gear and the shaft. Probably won't need more than a couple thou to close up the gaps.
If it's wedged in there pretty solidly, it'll be difficult to get it out (or, for that matter, to get the gear off the shaft).
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 21-02-2016, 01:27
MichaelBick MichaelBick is offline
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
If possible, you should bolt the gear directly to the arm while putting your encoder on the last stage pinion. This will minimize the effect of the slop in the hex bores, while also getting the most accurate arm position.
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
Unread 21-02-2016, 08:42
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
Rookie Year: 2011
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
There are ways to mechanically reduce the play, like pinning the connection, shimming, and the like. However, one thing that works rather well is preloading the connection with a counterbalance spring. We do this quite often by using surgical tubing to partially support the weight of various arms. It has the added benefit of often reducing the size of the actuator needed to provide the motion.
But, if you really want to do it mechanically, use a couple #4-40 screws and attach a hex shaft collar to the face of your sprocket. Position the sprocket with the collar loose, then tighten it up. (Disclaimer: never actually done this, but seems like it ought to work.)
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 21-02-2016, 08:46
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
I like Todd's idea better that this, but you could bearing retaining compound. The downside is you will not dissemble your mechanism without heat and maybe a press.
Controls wise: maybe a deadband and keep the D term small or zero.
If you don't know what you should hook up then you should read a data sheet
