Go to Post Just once I'd love to see a team come out to the field and say " Team xxxx rejects our reality and accepts yours!" - Koko Ed [more]
Unread 21-02-2016, 10:52
v5190robo v5190robo is offline
FRC #5190
v5190robo is an unknown quantity at this point
How to calculate distance from camera using Opencv APIs
Hi,
Is there any Opencv APIs or image processing algorithms in Opencv that can be used to calculate the distance of the camera from the target.
Thanks,
Vijay
Unread 21-02-2016, 11:27
Cinnamon Toast's Avatar
Cinnamon Toast Cinnamon Toast is offline
FRC #3641 (The Flying Toasters)
Rookie Year: 2013
Cinnamon Toast is an unknown quantity at this point
Re: How to calculate distance from camera using Opencv APIs
Hi!
Depending on your opencv code this is very possible. The way we do vision processing we do blob detection of a particular target (biggest blob always is the one targeted). After we find the blob we draw a circle around it, and place a dot in the center of the circle. For pose correction we use the pixel coordinates of the dot that we draw. Something else we do get from the code is the radius of the circle that we drew. As the camera gets farther away from the target, the target gets smaller, and so does the circle that we drew around the blob. By taking a couple of measurements, you can just create a linear relationship between radius of the circle and real world distance. The calculation actually holds up pretty well, as we plan to use it for targeting this year.
-Cinnamon Toast.
P.S. PM me if you want some sample code with opencv and stuff. I'd be willing to help.
