Go to Post [in response to http://www.welovefirst.com/] I feel like I've just been FIRST Rick Rolled. - kramarczyk [more]
Unread 21-02-2016, 12:01
Cinnamon Toast's Avatar
Cinnamon Toast Cinnamon Toast is offline
FRC #3641 (The Flying Toasters)
Rookie Year: 2013
Cinnamon Toast is an unknown quantity at this point
Questionable Results from Ultrasonic
I'm wondering if anyone else has had this problem...,
We've looked into using ultrasonic sensors from maxbotix to go ahead and try distance sensing for aiming. We did some benchmarks under very optimal conditions (hard target surface, no objects to the side to accidentally detect, and so on) and the results aren't stunning. After a very short distance ( 1 - 2 meters), it seems that the distance readings tend to break down. After a couple of meters, it'll return the correct distance half the time and then return something way to short. Has anyone else had this problems with the Ultrasonic sensors? If so, how did you over come it?
-Cinnamon Toast
Unread 21-02-2016, 15:32
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: Questionable Results from Ultrasonic
I'm not sure from your description which sensors you're using, or whether you're having trouble at ranges longer than 1-2 meters or shorter than 1-2 meters. Most inexpensive ultrasonic sensors have a minimum effective range of several feet. If you want short ranges, look into optical sensors; Sharp makes a number of short-range optical sensors (presumably designed for copiers) that they market as standalone sensors (Pololu, RobotShop, and SparkFun carry some of them, as well as many other vendors). We've had performance fully up to the specifications with several of these.
Unread 21-02-2016, 21:15
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
Rookie Year: 2012
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
We had an ultrasonic that worked great up to 15' or so, unless the robot was moving. The readings would be 1/2 to 1/4 the actual value. Couldn't figure out why. Had to scrap the idea.
Unread 22-02-2016, 21:10
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
Gave up on them two years ago. Never could seem to get consistent distance readings from them.
Unread 22-02-2016, 23:47
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Team Role: Leadership
Rookie Year: 1998
Mr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond repute
There are issues when more than robot is using the same type of ultrasonic sensor on the field. They can interfere with each other if they use the same frequencies.
Also, you should implement a circular buffer that takes median readings to filter out noisy/bad reads:
http://www.maxbotix.com/articles/129.htm
We used to use these ultrasonics on our robot with some success, but don't expect really great precision. Often you just aren't sure which surface you are measuring distance to, as the detection cone can be pretty wide. To use this year's field as an example, are you detecting the wall of the tower? back of a goal? lip on the batter? batter divider? hanging bar? any of those surfaces will give you slightly different distance reads.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 23-02-2016, 13:33
AKA: Mr Tanguay
You may wish to consider this:
https://acroname.com/products/SHARP-...16-GP2Y0A710YK
We've had some good results using IR sensors for distance measurement. This sensor has a pretty decent range though we've not used them yet. Ours have been much shorter in range for detecting objects on the robot itself. If you decide to try it let us know how it worked out for you.
Unread 01-03-2016, 21:08
Rookie Year: 2013
These IR distance sensors look like quite the feasible alternative. Does anyone have some info on how to implement them? Wiring and programming wise? The ultra sonics are easy as you just read the milivolts back and do the conversion with the multiplication values offered by maxbotix. Is it possible that anyone could give me a code snippit that would give me back a readable distance from one of these sensors?
Unread 01-03-2016, 21:58
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
They are analog so they work the same way. Voltage proportional to distance.
Unread 01-03-2016, 23:08
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Rookie Year: 2013
To sort of tie a bunch of things together - the ranges and clutter threshold at which ultrasonic works well does not have a lot of overlap with FRC conditions. IR or visual rangefinders usually work better than ultrasonic at shorter ranges (up to about 2 meters/6 feet), and vision processing is better than ultrasonic at longer ranges, especially if there is retroreflective tape on the target. Use green light; FRC fields usually abound in red and blue LEDs (2016 is no exception). Use the color info from your camera: at simplest, just use the blue channel; even better may be a calculation which considers red and blue light as being of a negative value.
Unread 02-03-2016, 15:04
AKA: Mr Tanguay
To be honest, we use them to sense the presence of an object on the robot. We just look for a certain threshold voltage to sense this. While they can be used to measure distances the response curve is non-linear so some kind of table look-up function might be needed to convert a measured voltage to the distance measured.
Unread 02-03-2016, 16:53
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Caleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond repute
I'm not sure which ultrasonic sensor you have observed this with, but we have used multiple maxBotix ultrasonic sensors over the past two years and they have all had extremely linear responses over their recommended ranges.
