Go to Post 2015 never happened - Chris is me [more]
Unread 21-02-2016, 14:09
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Rookie Year: 2013
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
AndyMark 8 Inch pneumatic hub fail
All,
We took apart our drivetrain to give it some TLC today and discovered all of our 8 inch pneumatic hubs are failing. Very similar to the rhino tread pulleys.
If you are using them, I suggest you take a close look are your hubs.
I just sent pictures to AndyMark and we awaiting for a reply.
Locktite was just applied, it was not there before about an hour ago.
http://imgur.com/a/DX4OH
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Unread 21-02-2016, 14:13
SamM SamM is offline
FRC #5842 (Royal Robotics)
Team Role: Teacher
SamM is just really niceSamM is just really niceSamM is just really niceSamM is just really niceSamM is just really nice
Re: AndyMark 8 Inch pneumatic hub fail
Is that loctite on the nuts? Loctite will destroy the polycarbonate hubs.
"The universe is probably littered with the one-planet graves of cultures which made the sensible economic decision that there's no good reason to go into space--each discovered, studied, and remembered by the ones who made the irrational decision." -Randall Munroe, XKCD
Unread 21-02-2016, 14:15
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
They're failing because you put loctite on your screws.
You shouldn't have done that for 2 reasons, the first being that loctite will melt the plastic, the second being that it's pointless because you're using nylock nuts.
2001-2004: Team 100
2006-Present: Team 254
Unread 21-02-2016, 14:27
orangemoore orangemoore is online now
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
Rookie Year: 2013
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Even have been using these hubs successfully without using any loctite.
It seems like this isn't Andymark's fault.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 21-02-2016, 14:38
AKA: Clint Brawley
FRC #0364 (Fusion)
Rookie Year: 2013
The locktight was just applied to get through the next couple of days!
The damage goes all the way through the hubs.
I highly suggest everyone using these take to a look at your hubs.
Clint Brawley
USAF 1992-2013
Unread 21-02-2016, 14:50
troy_dietz's Avatar
troy_dietz troy_dietz is online now
3D printing and Alliance Captain
FRC #0330 (The Beach Bots)
Team Role: Human Player
Rookie Year: 2015
troy_dietz is on a distinguished road
You don't need loctight when you use nylock nuts...
Looking at how much excess loctite is on the hub, that damage could have easily been done by a combination of chemical breakdown and stress on the plastic.
Unread 21-02-2016, 14:53
AKA: Clint Brawley
FRC #0364 (Fusion)
Rookie Year: 2013
Locktite was just applied, it was not there before about an hour ago. After the damage was found a student put the locktite on in an act of desperation.
Clint Brawley
USAF 1992-2013
Unread 21-02-2016, 15:00
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
Team Role: Coach
Rookie Year: 2010
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
What did you anticipate loctite helping with that the lock nuts weren't already doing for you?
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 21-02-2016, 15:27
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Everyone, please read the thread BEFORE responding.
The Locktite was added AFTER the failure. It is NOT the cause of the failure.
I believe the nylock nuts may have actually contributed to the failures.
Some nylock nuts have larger outside dimentions than the comparable regular nuts.
Forcing the larger nut into the hex opening, and over tightening them may crack the polycarbonate.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 21-02-2016, 17:02
Cory's Avatar
AKA: Cory McBride
We did read the thread. He edited his original post to say that it was applied after the damage appeared.
[edit] On closer inspection there are some cracks around the nut cavities that look like they might be consistent with slightly too large of a nut.
2001-2004: Team 100
Unread 21-02-2016, 17:08
AKA: Clint Brawley
FRC #0364 (Fusion)
Rookie Year: 2013
Look, I'm not trying to get anything other than the word out to check your hubs.
The locktite was applied after the fact.
We are fixing our issue, just make sure you don't have the same one.
Clint Brawley
USAF 1992-2013
Unread 21-02-2016, 17:14
billbo911's Avatar
I'm not saying OP is a liar, but that damage looks a lot like the damage loctite would create when applied to plastic. See this picture
No argument. Locktite WILL cause this type of failure!
Forcing in nuts that are too large for the opening can crack the polycarbonate too. Just my $.02.
Unread 21-02-2016, 17:24
Landonh12's Avatar
Landonh12 Landonh12 is offline
270 points
AKA: Landon Haugh
FRC #0364 (Team Fusion)
Rookie Year: 2012
Landonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud of
We added the loctite in an attempt to try and keep things still. Obviously, with a hub that is nearly disintegrating around the bolts, a substance needs to be applied to hold things together until a permanent fix has been applied.
We used the nylock nuts included in the mounting hardware for these hubs, purchased from AndyMark (http://www.andymark.com/product-p/am-2021.htm). These are the correct nuts from my understanding.
Sorry for our ignorance. We simply did not know that loctite eats away at polycarbonate. We are currently looking at other options.
EDIT: Another thing. The center hubs (6 wheel 1/8" center drop) were not damaged as much as the outside hubs. We have been stress testing our robot by hitting defenses as much as possible.
Team Fusion 364 - Driver/Programmer 2012-2015; Controls Mentor 2016-Present
Unread 21-02-2016, 18:02
Team Role: Coach
Rookie Year: 2010
No ignorance implied, I was simply curious as to what you thought a thread locking substance was going to achieve there.
How much air pressure did you fill your tires to? Did you check the outsides of the hubs as well (take the tire off and really check)? I would be curious if there was any impact directly to the wheel itself that wasn't absorbed by the tire due to a low pressure situation.
Andrew Basse
  #15   Spotlight this post!
Unread 21-02-2016, 18:13
waialua359's Avatar
waialua359 waialua359 is offline
Mentor
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Rookie Year: 2000
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
Thanks for the heads up. I can see the barriers being the main culprit due to the stress on the wheels and not be surprised if that ends up being the case.
We've broken plaction wheels before in 2010.
It's a good thing we decided to machine our own rims.
2016 Hawaii Regional #1 seed, IDesign, Safety Award
2016 NY Tech Valley Regional Champions, #1 seed, Innovation in Controls Award
2016 Lake Superior Regional Champions, #1 seed, Quality Award, Dean's List
2015 FRC Worlds-Carver Division Champions
2015 Hawaii Regional Champions, #1 seed.
2015 Australia Regional Champions, #2 seed, Engineering Excellence Award
2015 Inland Empire Regional Champions, #1 seed, Industrial Design Award
2014 OZARK Mountain Brawl Champions, #1 seed.
2014 Hawaii Regional Champions, #1 seed, UL Safety Award
2014 Dallas Regional Champions, #1 seed, Engineering Excellence Award
2014 Northern Lights Regional Champions, #1 seed, Entrepreneurship Award
2013 Championship Dean's List Winner
2013 Utah Regional Champion, #1 seed, KP&B Award, Deans List
2013 Boilermaker Regional Champion, #1 seed, Motorola Quality Award
2012 Lone Star Regional Champion, #1 seed, Motorola Quality Award
2012 Hawaii Regional Champions #1 seed, Motorola Quality Award
