Go to Post The world isn't made out of Nerf, you will get scrapes and bruses, but you will get back up and continue on. If you watch out you can avoid the sharp edges. - Joe Matt [more]
  #16   Spotlight this post!
Unread 21-02-2016, 17:21
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
Mentor / Bayou & CMP Division LRI
FRC #0456 (Siege Robotics)
ChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond repute
Re: AndyMark 8 Inch pneumatic hub fail
Clint,
We have 8 of the hubs here in our shop if you need them ASAP get someone on the road to Vicksburg if you need them before bag and tag. If not we can bring them to you next Saturday in Oxford.
-Chuck
  #17   Spotlight this post!
Unread 21-02-2016, 17:24
Landonh12's Avatar
Landonh12 Landonh12 is offline
270 points
AKA: Landon Haugh
FRC #0364 (Team Fusion)
Rookie Year: 2012
Landonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud of
Originally Posted by MrBasse View Post
What did you anticipate loctite helping with that the lock nuts weren't already doing for you?
We added the loctite in an attempt to try and keep things still. Obviously, with a hub that is nearly disintegrating around the bolts, a substance needs to be applied to hold things together until a permanent fix has been applied.
Originally Posted by billbo911
Forcing in nuts that are too large for the opening can crack the polycarbonate too. Just my $.02.
We used the nylock nuts included in the mounting hardware for these hubs, purchased from AndyMark (http://www.andymark.com/product-p/am-2021.htm). These are the correct nuts from my understanding.
Sorry for our ignorance. We simply did not know that loctite eats away at polycarbonate. We are currently looking at other options.
EDIT: Another thing. The center hubs (6 wheel 1/8" center drop) were not damaged as much as the outside hubs. We have been stress testing our robot by hitting defenses as much as possible.
Team Fusion 364 - Driver/Programmer 2012-2015; Controls Mentor 2016-Present
  #18   Spotlight this post!
Unread 21-02-2016, 18:02
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
Team Role: Coach
Rookie Year: 2010
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
No ignorance implied, I was simply curious as to what you thought a thread locking substance was going to achieve there.
How much air pressure did you fill your tires to? Did you check the outsides of the hubs as well (take the tire off and really check)? I would be curious if there was any impact directly to the wheel itself that wasn't absorbed by the tire due to a low pressure situation.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
  #19   Spotlight this post!
Unread 21-02-2016, 18:13
waialua359's Avatar
waialua359 waialua359 is offline
Mentor
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Rookie Year: 2000
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
Thanks for the heads up. I can see the barriers being the main culprit due to the stress on the wheels and not be surprised if that ends up being the case.
We've broken plaction wheels before in 2010.
It's a good thing we decided to machine our own rims.
2016 Hawaii Regional #1 seed, IDesign, Safety Award
2016 NY Tech Valley Regional Champions, #1 seed, Innovation in Controls Award
2016 Lake Superior Regional Champions, #1 seed, Quality Award, Dean's List
2015 FRC Worlds-Carver Division Champions
2015 Hawaii Regional Champions, #1 seed.
2015 Australia Regional Champions, #2 seed, Engineering Excellence Award
2015 Inland Empire Regional Champions, #1 seed, Industrial Design Award
2014 OZARK Mountain Brawl Champions, #1 seed.
2014 Hawaii Regional Champions, #1 seed, UL Safety Award
2014 Dallas Regional Champions, #1 seed, Engineering Excellence Award
2014 Northern Lights Regional Champions, #1 seed, Entrepreneurship Award
2013 Championship Dean's List Winner
2013 Utah Regional Champion, #1 seed, KP&B Award, Deans List
2013 Boilermaker Regional Champion, #1 seed, Motorola Quality Award
2012 Lone Star Regional Champion, #1 seed, Motorola Quality Award
2012 Hawaii Regional Champions #1 seed, Motorola Quality Award
  #20   Spotlight this post!
Unread 21-02-2016, 18:29
Landonh12's Avatar
270 points
AKA: Landon Haugh
Rookie Year: 2012
We did have the pressure below specifications. We did this because we believed using a lower pressure would help absorb shock from ramping over the defenses.
  #21   Spotlight this post!
Unread 21-02-2016, 21:27
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is online now
AKA: Clint Brawley
FRC #0364 (Fusion)
Rookie Year: 2013
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
Chuck, thanks for the kind offer!
All, here is situation.
The pressure in the outside wheels was at 15 PSI with the center wheels being at 25 PSI.
We went to add pressure today when we noticed that the frame had a bit of wood from our defenses. Indicating that our tires were compressing enough to allow the wood to contact our frame. Our frame is designed so that the defense can not directly touch the wheel hubs even without a tire on the hub. We have at least a 0.5 inches of aluminum between the hub and any outside contact.
We used the hardware from AndyMark on the Hubs without any locktite.
We drove the heck out of these, thinking we would rather brake it in house that at a competition.
It broke, just not where we thought we were vulnerable.
V/r
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
  #22   Spotlight this post!
Unread 21-02-2016, 23:04
chapman1's Avatar
chapman1 chapman1 is offline
FRC #3688 (Suttons Bay Norsemen Robotics)
Team Role: Coach
Rookie Year: 2011
chapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond repute
In my opinion (and I recognize the difference between my opinion and fact) the Loctite was not a factor, unless you poured quarts of it into a container and soaked your hubs in it over the summer. Based on what you said about the failure location, I assume you did not.
You stated that you tested the robot hard, deliberately trying to break it. That is good engineering practice (again, my opinion).
I'm assuming that knowing you were going to do this, your team decided to eliminate as many weak points as possible. Nylock nuts are not 100% nylon, and so, you took advantage of the metal-to-metal contact and added a few drops of Loctite. Pretty sure that did not cause the hubs to fail.
So, you found the weak point in the wheel-hub system that a majority of teams seem to be using this year - the hubs - and you shared it. THANK YOU. This will help a lot of teams.
It seems that this year, more than years past, people are quick to jump on those who post. It's almost painful to read some of the comments when a team posts a CAD rendering of a robot and some of the comments are tantamount to "that looks like 14 gauge wire - don't you know that a CIM requires..."
Come on, people, be grateful when someone shares potentially helpful information - and be helpful with our comments and discussion rather than critical. This is, after all what we're supposed to be doing, right? Setting an example, right?
  #23   Spotlight this post!
Unread 21-02-2016, 23:16
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
Rookie Year: 2011
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
V/r
If you've done any serious testing, this may be the root cause. Here is some video of our robot going over defenses. Take a look at the slow motion clips near the middle of the video. See the tires compressing nearly all the way to the rims? This was with tire pressure of 35psi. If you were running at 15 psi on your outer wheels, and hitting your defenses as hard as we have been, I have to think your tires have been fully compressing. I don't think the rims would last long if that were the case.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
