Go to Post Insanity is overrated. - MissInformation [more]
Unread 21-02-2016, 15:11
marshmello marshmello is offline
FRC #1711 (The Raptors)
Team Role: Mechanical
Rookie Year: 2015
marshmello is an unknown quantity at this point
Power draw issues
We're having power draw issues and we have no idea what's causing them.
Our drive train is four cims, two tough box minis, and belts driving six 8" harbor freight tires. We're having this weird issue where we're drawing more power than we seem to be using, so much that the Rio kinda shuts itself down and driving becomes erratic and slow to respond.
We don't think it's a code issue, and we've replaced the cims, disassembled and reassembled the gearboxes, and checked the talon srx's we have on the cims multiple times. Someone brought up the idea that our wires were too small of a gauge, but we think they would be melting if that were the issue.
We have been having this problem since a little after we started driving last week. Any ideas would really be appreciated...
Unread 21-02-2016, 15:20
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Power draw issues
The problem, is that you are using wheels that are too large and grippy for the drivetrain you have connected to them. It's kind of late in the build season to fix this....but suggestions would be to see if you can adjust the height of one pair of end wheels to make it sit up higher than the others, or maybe replace one set of end wheels with something a little smaller, or with less traction.
The basic problem of having not enough gear reduction ratio in the transmissions is harder to fix. If you can get pulleys (or chain sprockets) with different sizes, then you could get more speed reduction (an torque increase) and it would help.
without pictures of your robot, to see how it's built, it's not easy to make useful suggestions.
Unread 21-02-2016, 15:23
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
For a torque increase you can swap the standard 10.71:1 ratio in the toughbox mini to a 12.75:1 ratio using a different gear set (if you haven't done it already). If you have the old toughboxes you can use those gears inside the toughbox mini since they are interchangeable and are geared to 12.75:1
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 21-02-2016, 15:27
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
In addition you can swap to a 13 tooth pinion instead of a 14 tooth pinion to get additional torque. I made these recommendations to another team this season.
13 Tooth Pinions: Switch to 13 Tooth pinion gears $8 each, $32 total. Slows down your drive train but gives you more power for climbing, etc, makes your robot more controllable. http://www.vexrobotics.com/vexpro/mo...tor-gears.html
Reduce 2nd Stage: If you are using 8” wheels, Switch the 2nd stage of your drivetrain to 14 to 50. You could also use the VEXpro 14 tooth ⅜ hex gear and the 50 tooth ½” hex gear but you would need to mess around with spacing inside the gearbox. $42 Total
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
Unread 21-02-2016, 16:08
Rookie Year: 2015
Why would adjusting the height work? I was wondering because that's kinda out of the question, and I want to see if there's something else I could to to achieve that end.
Unread 21-02-2016, 17:56
Chris Mounts's Avatar
Chris Mounts Chris Mounts is offline
FRC #1188 (Oaktown Crewz)
Team Role: Coach
Rookie Year: 2010
Chris Mounts is an unknown quantity at this point
Adjusting the height reduce the scrub effect of trying to turn with 3 wheels on the ground. Pneumatics really need a larger drop center than the stock chassis has.
With time so short the real question is what parts do you have on hand? Are you using the AM14U3 chassis?
Unread 21-02-2016, 19:07
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
In addition to telling us how much your center wheel is lowered (you really need to be able to see that front wheels off the floor when your rear wheels are on the floor and vice versa). I am still not clear what your ratio is from the CIM to the Wheels, specifically what is the ratio from the Toughbox to the wheels.
Have you used JVN's spreadsheet to figure out your top speeds and pushing current? If not, you really should make this a standard thing you do going forward.
If you are using chain*, you have some ABS sheets around and access to an Epilog laser cutter, you can make new wheel sprockets in an afternoon. With the exception of really small sprockets (<20 teeth or so), I've used nothing but ABS sprockets for years now.
Back to the power draw issues, in the short term you can try adding a little extra air to the middle wheel to increases the rock. You can also do things to reduce the grippiness of the front and back tires (test it with some duct tape).
Dr. Joe J.
*I know that a lot of smart folk really like belts but I am just not there yet because of the freedom to change sprockets without needing new belts. After seeing so many belt drive lifts last year, I think I am sold when it comes to lifts but for drives, I still like chain.
Joseph M. Johnson, Ph.D., P.E.
Mentor
Team #88, TJ2
Unread 21-02-2016, 20:12
Rookie Year: 2015
We are using a custom chassis, basically two boxes assembled from 1/8 aluminum with a lexan belly pan in between, reinforced with 1x2 tubing and churros. We have a lot of stock metal, plastic, and wood on hand, and access to a professional metalworking facility.
Also, all of our wheels touch the ground at once, we're using belts and 3d printed pulleys, and we have a 10.71:1 gear ratio.
Unread 21-02-2016, 20:27
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp), FRC #1592 (Bionic Tigers)
Team Role: Tactician
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
We where having verry simmilar issues with our 6wd 4 cim harbor freight wheeled drivetrain geared for 20:1 with a 3/8 wheel drop. The problem was rooted back to poor structural regidity. By simply adding 2 pieces of churo tubbing between the gearboxes and a piece of c channel in the front (standing in for our intake) we fixed the problem.
Past teams:
1523 (2011-2014)
1065 (2014-2016)
3932 & 4592 (2016)
Unread 21-02-2016, 20:31
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Yeah, but look at your gear ratio and center drop:
... that's why it works.
Unread 21-02-2016, 20:35
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
Rookie Year: 2014
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
You could simulate a center drop by inflating your outer wheels less than the center wheel. It's not ideal but it's something you can do without having to buy any new parts.
Unread 21-02-2016, 20:36
wjd13 wjd13 is offline
FRC #4905 (Andromeda One)
Rookie Year: 2015
wjd13 is an unknown quantity at this point
Our team is also having some power issues, the roborio will restart very often, especially when we try turning on carpet, or going over defenses. Our team is wondering if battery age could be a significant issue. The lead acid batteries we were using today are 3 years old, and apparently weren't taken care of properly the past 3 years (according to an electrical mentor). We're getting some new batteries, and hopefully that will relieve some of the issues.
Unread 21-02-2016, 19:12
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Team Role: Leadership
Rookie Year: 1998
Mr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond repute
Over inflate your middle wheels and under inflate your outer ones. This alone won't be enough though, and you may need to wrap your outer wheels in tape - something slippery.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 21-02-2016, 19:20
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
All closely related threads:
Power draw issues
Battery Voltage problem
Voltage Drop issues
Robot loses communication while going over obstacles
Router browns out with multiple CIMS driving WCD
Mentor
Team #88, TJ2
  #15   Spotlight this post!
Unread 21-02-2016, 21:16
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Rookie Year: 2007
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
Something interesting we noted:
With no load(weight) on the tires decreasing the air pressure can actually increase the diameter. It seems that as we add air pressure, the side walls of the tire bulge out more decreasing the diameter.
- Bochek
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
