Go to Post if it's likely to break, it probably will - DonRotolo [more]
Unread 21-02-2016, 16:20
Bernstern Bernstern is offline
FRC #2141 (Spartonics)
Rookie Year: 2015
Bernstern is an unknown quantity at this point
trying to use usb webcam with opencv
Hello,
My team has been trying to use the Tower tracker program to little avail, but our hardest challenge is using our Microsoft webcam as the vision input. I checked out mjpeg streamer but couldn't understand it and have gotten no where with it. Any help would be greatly appreciated/
Programmers, a species indigenous to robotics that can convert caffeine into code.
Unread 21-02-2016, 18:46
Noviv's Avatar
Noviv Noviv is offline
FRC #1477 (Texas Torque)
Rookie Year: 2013
Noviv is an unknown quantity at this point
Re: trying to use usb webcam with opencv
My team isn't using the Tower Tracker program, so I can't help you with that, sorry.
But, if you are using OpenCV in C/C++, all you should have to do is declare a new VideoCapture and use the Mat that you get from the device. You can then play around with the Mat using OpenCV functions (just google what you want to do).
Code:
#include "opencv2/opencv.hpp"
int main() {
    VideoCapture cap(0);
    Mat frame;
    namedWindow("Webcam");
    while (true) {
        cap >> frame;
        //opencv functions go here
        imshow("Webcam", frame);
        if (waitKey(30) >= 0) {
            break;
    cap.release();
If you have another webcam on the computer/device you are running this program on, just increase 0 to 1, 2, etc until you get the right device.
