Go to Post Also, If I am not mistaken, the name indicates that your robot is female :P They're all female... like cars, ships, and airplanes. - JVN [more]
Unread 21-02-2016, 19:47
khannasusa khannasusa is offline
FRC #5190
khannasusa is an unknown quantity at this point
How to Cancel a PID on a CAN Talon SRX?
We an arm on our robot and we can raise/lower i fine using a Position closed loop.
When we press a Button 1, arm goes up 10 Degrees say.
When we press a button 2, arm comes down 10 degrees.
But when arm comes down to its home position (bottom most down), how do we cancel the PID, so the motor and talon both stop putting a throttle?
Thanks
--sk
Unread 22-02-2016, 00:36
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: How to Cancel a PID on a CAN Talon SRX?
Put the Talon SRX into %Vbus mode and command a speed of 0.
Unread 22-02-2016, 01:01
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Another option is to use a soft limit.
