Go to Post Heaven forbid. A hexed Vex. - Warren Boudreau [more]
Unread 21-02-2016, 22:15
rahilm's Avatar
rahilm rahilm is offline
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
Rookie Year: 2007
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
VersaPlanetary Failures
Hi all,
Looking for some advice if anyone has seen failures like this before or has insight into the root cause, so we can prevent it from happening again. I've attached some pictures, but basically what we're seeing is the pins the planet gears rotate on begin to push out, eventually rubbing against the casing and causing large amounts of friction and seizing of the gearbox.
Pictures here:
http://imgur.com/a/hG4J0
Thanks in advance.
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
