Go to Post Judging the Championship CA must be the hardest thing to do in FIRST. I'd rather try to stop an alliance of 1114, 111, and 25 from scoring 3 pointers than to judge the CA between these teams. - Andy Baker [more]
Unread 22-02-2016, 07:35
Tzury-Orbit1690 Tzury-Orbit1690 is offline
FRC #1690 (Orbit)
Team Role: CAD
Rookie Year: 2015
Tzury-Orbit1690 is just really niceTzury-Orbit1690 is just really niceTzury-Orbit1690 is just really niceTzury-Orbit1690 is just really niceTzury-Orbit1690 is just really nice
Orbit 1690 REAL robot reveal! - "SKYZER"
FRC team Orbit 1690 from Binyamina, Israel, presents it's 2016 robot for the game STRONGHOLD !
https://www.youtube.com/watch?v=5i92qk6E9_k
2015 - orbit #1690 cad team member
2016 - orbit #1690 head of cad team
Unread 22-02-2016, 08:04
ghesla's Avatar
ghesla ghesla is offline
FRC #1156 (Under Control)
ghesla is a glorious beacon of lightghesla is a glorious beacon of lightghesla is a glorious beacon of lightghesla is a glorious beacon of lightghesla is a glorious beacon of lightghesla is a glorious beacon of light
Re: Orbit 1690 REAL robot reveal! - "SKYZER"
Great Robot as usual!
Good luck 1690!
1156 Under Control
2015 SBPLI Long Island Chairman's Award Winner
2015 Curie Division quarter-finalist
2014 & 2016 Long Island Regional Winner
Unread 22-02-2016, 08:16
Type's Avatar
Type Type is offline
FRC #3452 (GreengineerZ)
Team Role: Mechanical
Rookie Year: 2016
Type is an unknown quantity at this point
Great job! That shooter looks amazing! I wish my team's robot had a shooter as acurate and powerful as that.
Unread 22-02-2016, 16:33
Tomker's Avatar
Tomker Tomker is offline
AKA: Tom Kertesz
FRC #1690 (Orbit)
Rookie Year: 2010
Tomker will become famous soon enough
Thanks for the compliments.
To add to the original post and the video itself, We wanted to share some of the robot's specs:
Drivetrain:
  • 8 x 6" WCP Pneumatic tires (Diamond tread) with a 4mm (~5/32") center drop
  • 2/3 CIM Custom 2 stage single speed gearbox (Currently sporting 2 CIMs) with a total reduction of 9:1
  • One Wheel direct driven by the gearbox and the others are driven using #35 chain
  • Theoretical top speed of 15.4ft/s (4.7m/s)
  • Front angled wedge to allow for easier traversing of defenses
Intake + Defense Manipulator:
  • Front horizontal roller with 6 x 2" AM stealth wheels for initial acquisition of boulders
  • 4 Vertical rollers with 2" AM stealth wheels used to center and push boulders through the bumper opening
  • Each driven by one AM-9015 motor through a 12:1 versaplanetary
  • Omni wheel on each side of the mechanism to prevent friction with the ground
  • Snowblower motor through a 4.5:1 reduction used to raise and lower the mechanism
  • Doubles as a manipulator for both the Portcullis and Cheval De Frise
Shooter:
  • Shooter arm actuated using a 6" stroke DART actuator powered by a CIM motor
  • 2 sets of 2 x 4" AM stealth wheels driven by a single MiniCIM using timing belts
  • Bottom wheels spin 1.8 times faster than the top ones to generate backspin for improved accuracy
  • A mechanism that we named 'The Spoon' is used to keep the boulder in place while picking up or driving around, pull it away from the shooting wheels to allow them to accelerate and push it into the shooter at the right speed
  • The Spoon is driven up and down using a Snowblower motor
Controls:
  • Each side of the drivetrain has a AMT103-V encoder
  • A potentiometer is used to control the angle of the intake mechanism and another on the DART the control the shooter angle
  • An AMT103-V encoder is used to determine and monitor shooter speeds
  • Two micro-switches are used to create 3 set positions for the spoon (Lowbar, Boulder tangent to shooting wheels, accelerating shooter)
  • A camera is mounted on the shooter arm and used for vision processing to accurately align the robot to goal in the X axis and to control the shooter speed
  • An Analog Devices Accelerometer & Gyro is mounted on the Roborio to allow us to fix any misalignment caused by traversing the defenses in autonomous
Hanging(?):
  • A mechanism was designed using a tape measure and a winch and was sent to manufacturing today. It will be assembled on our practice bot and hopefully - if it works, will be fitted on the competition robot in the Israeli regional in a couple of weeks (stay tuned to see how this thing comes along)
Our whole design is focused around the idea of both being able to go under the lowbar and shooting high from the outerworks line, while releasing the boulder from as high and as far back in the robot as possible. This should essentially make us unblockable from this position because by the time the boulder exits our perimeter it is already higher than a defending robot's maximum height.
I'm also adding a little example of a quick pickup and shoot practice we had earlier today (8/8 shooting in this small snippet):
http://youtu.be/PWZr92l8abI
Unread 22-02-2016, 17:59
This might be my favorite reveal so far. If I didn't know any better I would mistake the design work for a Team IFI robot. Excellent!
Unread 22-02-2016, 18:49
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
Awesome.
I like the stabilization during shooting (at least that is what I think you put the front arm down for during shots -- it could be to keep other robots back a bit from your shooter but I am guessing that it's a stabilization thing).
Dr. Joe J.
Joseph M. Johnson, Ph.D., P.E.
Mentor
Team #88, TJ2
Unread 22-02-2016, 18:56
Tomker's Avatar
AKA: Tom Kertesz
FRC #1690 (Orbit)
Rookie Year: 2010
Originally Posted by Joe Johnson View Post
Awesome.
Dr. Joe J.
It's both. Initially it was mainly to keep defending robots back, but after driving around a little we realized the robot could get a bit unstable when both the shooter arm and intake are in their top position (which is only used pre-match for starting configuration purposes), we decided we are definitely better off having the intake down when shooting...
Unread 22-02-2016, 23:27
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is online now
AKA: Clint Brawley
FRC #0364 (Fusion)
Rookie Year: 2013
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
Nice bot!
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Unread 23-02-2016, 19:26
the.miler's Avatar
the.miler the.miler is offline
taking a break
AKA: Miles Chan
FRC #0846 (Funky Monkeys)
Rookie Year: 2011
the.miler is a glorious beacon of lightthe.miler is a glorious beacon of lightthe.miler is a glorious beacon of lightthe.miler is a glorious beacon of lightthe.miler is a glorious beacon of light
Really surprised this robot hasn't gotten more attention, as it combines the key features of low bar traversal, wide floor collecting range, and high shooter release point in a very logical design. Props to the group of people who came up with your strategic and robot design priorities; this is a high quality shooting robot.
Some of my initial questions:
What motivated your decision to shoot from the protection offered from the outerworks? Does it have anything to do with your cycle speed/consistency? Do you plan on being capable of shooting from the batter as well?
How does your shooter perform with balls of different compliances? It clearly shoots well with at least one particular ball, but at competition you play with the balls on the field.
Good luck on the field; you have a great shot at doing well.
Member 846 The Funky Monkeys 2010-2014
Team 846 Highlights 2014
lynbrookrobotics.com
becauserobots.org
Unread 23-02-2016, 20:20
Tomker's Avatar
AKA: Tom Kertesz
FRC #1690 (Orbit)
Rookie Year: 2010
We figured that at least at the final stages of each competition defense being played on high goal shooters will be fierce. Since our main focus was on being a good shooter, we felt like this gives us the best chances of scoring consistently.
In addition, we wanted to minimize the amount of ground we have to cover until we are aligned for a shot, and the best obvious option (assuming we just picked up a boulder and crossed a defense) is as closely as possible to the outerworks
We haven't really tested this capability, but in theory i'm pretty sure we can tilt our shooter arm back far enough to achieve the needed angle to score from the batter. I guess that if the need arises we'll adjust and add this option.
We did practice with 2 different balls most of the time and saw no apparent difference between their behaviors. As long as the boulders are in reasonable condition we seem to be fairly unaffected by the small changes. Of course when they get really worn our they start to cause some problems and don't fly as fast or as high, but we believe the boulder condition during competition should not get bad enough for us to not score consistently.
Anyway, we are capable of readjusting our shooter speed in accordance with boulders condition.
Unread 23-02-2016, 23:09
ajacob ajacob is offline
Lead Programmer
FRC #2791 (Shaker Robotics)
Rookie Year: 2013
ajacob is an unknown quantity at this point
Hi I love you robot, I was curious on how you guys are lining up with the target, are you using pid? I would love it if I could see your code.
Unread 23-02-2016, 19:44
waialua359's Avatar
waialua359 waialua359 is offline
Mentor
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Rookie Year: 2000
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
Awesome looking robot.
Your team definitely did their homework on achieving both the lowbar lowbot and an unblockable shot.
As you pointed out, the dropping of the intake to create clearance for the shot is very clever.
2016 Hawaii Regional #1 seed, IDesign, Safety Award
2016 NY Tech Valley Regional Champions, #1 seed, Innovation in Controls Award
2016 Lake Superior Regional Champions, #1 seed, Quality Award, Dean's List
2015 FRC Worlds-Carver Division Champions
2015 Hawaii Regional Champions, #1 seed.
2015 Australia Regional Champions, #2 seed, Engineering Excellence Award
2015 Inland Empire Regional Champions, #1 seed, Industrial Design Award
2014 OZARK Mountain Brawl Champions, #1 seed.
2014 Hawaii Regional Champions, #1 seed, UL Safety Award
2014 Dallas Regional Champions, #1 seed, Engineering Excellence Award
2014 Northern Lights Regional Champions, #1 seed, Entrepreneurship Award
2013 Championship Dean's List Winner
2013 Utah Regional Champion, #1 seed, KP&B Award, Deans List
2013 Boilermaker Regional Champion, #1 seed, Motorola Quality Award
2012 Lone Star Regional Champion, #1 seed, Motorola Quality Award
2012 Hawaii Regional Champions #1 seed, Motorola Quality Award
