Go to Post If you never reach out and experiment with different things, you will never have the courage to reach out again. It's only through experiments and experiences where we get to understand ourselves better. - Ken Leung [more]
Unread 22-02-2016, 13:41
pilum40 pilum40 is offline
Steve Miller-Coach-Team 3355
AKA: Steve Miller
FRC #3355 (Bigg Redd)
Team Role: Coach
Rookie Year: 2010
pilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud of
Bottom Pan for Robot?
We are discussing putting a bottom pan on our robot and need to make a decision tonight. The discussion revolves around wood vs. thick plexi vs. old fashioned steel. We've got all the materials but wanted to see if this was overkill. I'm a bit old school in that I want to protect the bottom of the robot while going over the defenses and not get caught on them. We're using Rhino drive and are staying low so we can "low bar" easily. I'm also old school in that I recommend steel since we're way underweight. Thoughts? Any pearls would be welcome.
Thanks
Unread 22-02-2016, 13:43
waialua359's Avatar
waialua359 waialua359 is offline
Mentor
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Rookie Year: 2000
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
Re: Bottom Pan for Robot?
Thanks
We added a thin sheet metal belly pan below our perforated aluminum sheet and no issues now. We had zip ties which secures our control system parts rip off prior to that since they stuck out under the bottom of the perforated sheet.
2016 Hawaii Regional #1 seed, IDesign, Safety Award
2016 NY Tech Valley Regional Champions, #1 seed, Innovation in Controls Award
2016 Lake Superior Regional Champions, #1 seed, Quality Award, Dean's List
2015 FRC Worlds-Carver Division Champions
2015 Hawaii Regional Champions, #1 seed.
2015 Australia Regional Champions, #2 seed, Engineering Excellence Award
2015 Inland Empire Regional Champions, #1 seed, Industrial Design Award
2014 OZARK Mountain Brawl Champions, #1 seed.
2014 Hawaii Regional Champions, #1 seed, UL Safety Award
2014 Dallas Regional Champions, #1 seed, Engineering Excellence Award
2014 Northern Lights Regional Champions, #1 seed, Entrepreneurship Award
2013 Championship Dean's List Winner
2013 Utah Regional Champion, #1 seed, KP&B Award, Deans List
2013 Boilermaker Regional Champion, #1 seed, Motorola Quality Award
2012 Lone Star Regional Champion, #1 seed, Motorola Quality Award
2012 Hawaii Regional Champions #1 seed, Motorola Quality Award
Unread 22-02-2016, 13:47
BetaHelix's Avatar
BetaHelix BetaHelix is offline
FRC #4646
BetaHelix is an unknown quantity at this point
We have polycarbonate but steel could work.
Some questions though,
Is this structural or purely protective?
How thick/flexible is the plexi, wood, or steel?
Unread 22-02-2016, 13:48
hardcopi hardcopi is offline
AKA: Rich Lester
FRC #2959 (The Robotarians)
Rookie Year: 2013
hardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud of
We used a simple metal grate. Pretty light weight and strong.
Unread 22-02-2016, 13:53
Tim Sharp Tim Sharp is offline
Tim Sharp
FRC #3959 (Morgan County Mech Tech)
Team Role: Coach
Rookie Year: 2012
Tim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to beholdTim Sharp is a splendid one to behold
We made our belly pan from a 1/4" sheet of 5051 aluminum. We figured we would need it after crossing a couple of defenses at high speeds.
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Just as a thought... An awful lot of Defenses are, or have, steel in them. (Rock Wall and Rough Terrain come to mind immediately.) Steel on steel tends to produce sparks. Sparks tend to be bad, though they may look spectacular.
I'd use some thick sheet aluminum, maybe going up to thin plate aluminum. Wood is going to get shredded.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 22-02-2016, 14:26
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
From Week 0 events, I would want protection from driving over a ball.
Non-conductive is good. That minimizes the risk of accidentally grounding the frame to the battery.
Unread 22-02-2016, 14:30
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
What is the ground clearance between the lowest point on the robot and the ground?
Ours was ~3" until we realized we had to protect the WCP transmissions since they stick down ~0.75" below our frame rail. We added 'skid rails' made of thick-wall 1x1 aluminum tubing. This removed the need for a separate belly pan/protective layer.
We have some more profiling to do with them to help with the ramparts, but otherwise the skid bars help us with the moat and rockwall with simple 45-degree chamfers on either end.
GitHub
Unread 22-02-2016, 14:33
whitetail's Avatar
whitetail whitetail is offline
FRC #5407 (Wolf Pack)
Team Role: Operator
Rookie Year: 2014
whitetail is an unknown quantity at this point
For our robots bottom pan we just have 1/8 inch plexiglass and it works just fine. I don't think you think plexiglass for the bottom of the robot.
FRC Team 5407 -Driver, Programmer and Head Control Systems Engineer
2015 MAR Championship Rookie All Star Award
2015 MAR Hatboro-Horsham District Rookie All Star Award
2015 MAR Hatboro-Horsham District event Winner(Thanks 2590, 2607)
Unread 22-02-2016, 14:38
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Our lower cover is made of 0.10" thick polycarbonate. It is flexible, so we were able to make it curve up at the front end. And it only took about 15 minutes to make it and install it...
Unread 22-02-2016, 15:14
Type's Avatar
Type Type is offline
FRC #3452 (GreengineerZ)
Team Role: Mechanical
Rookie Year: 2016
Type is an unknown quantity at this point
I believe we have a 1/4" sheet of lexan that we also mount our electronics to. We don't have any issues with zip ties or nuts since we tapped all the wholes so we can just cut the bolts to the needed length.
Unread 22-02-2016, 15:21
lethc's Avatar
lethc lethc is offline
#gkccurse
AKA: Becker Lethcoe
FRC #1806 (S.W.A.T.)
Rookie Year: 2013
lethc will become famous soon enough
We're using a 1/8" sheet of lexan that completely covers the underside of our robot, front to back. We're avoiding mounting anything to it due to it needing to be quickly removable for easy access to components located lower in the robot.
2016: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Semifinalists, IRI Quarterfinalists
2015: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Quarterfinalists, IRI Winners
2014: Central Illinois Regional Quarterfinalists, Greater Kansas City Regional Finalists, Newton Semifinalists
2013: Greater Kansas City Regional Winners, Oklahoma Regional Winners, Galileo Quarterfinalists
Unread 22-02-2016, 15:40
team222badbrad's Avatar
team222badbrad team222badbrad is offline
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Rookie Year: 2000
team222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond repute
Send a message via AIM to team222badbrad
We use 1/16" polycarbonate.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 22-02-2016, 15:43
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
Rookie Year: 2013
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
We used 1/4" poly as our belly pan, we are also using rhino drive.
  #15   Spotlight this post!
Unread 22-02-2016, 15:46
OccamzRazor's Avatar
OccamzRazor OccamzRazor is offline
Go YETI!
AKA: Robbie
FRC #3506 (YETI)
OccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to behold
We use expanded aluminum for the best of both worlds. We do not need to drill holes for the electrical belly pan, it is lightweight, won't shatter, and it is stiff enough to bolt to the bottom of our robots easily with 1/4"-20 fasteners and washers. You could also weld it I suppose.
Here is the page where we get it: http://www.mcmaster.com/#expanded-metal/=118mlm3
We usually get the diamond shaped sheets. Cuts easily with sheet metal shears too.
2015 NC Regional Chairman's Award
2016 NC Guilford District Event Winner
2016 NC Guilford District Chairman's Award
2016 NC District Championship Winner
2016 NC Regional Chairman's Award
2016 NC Woodie Flowers Award Finalist - Lia Schwinghammer
