Go to Post 2015 never happened - Chris is me [more]
Unread 22-02-2016, 18:11
mjv5720 mjv5720 is offline
FRC #5720
mjv5720 is an unknown quantity at this point
Team 5720 Rhino Tracks Problems
We discovered that one of the pulley wheels on our rhino tracks isn't lined up and it's causing our robot to jump. Like the pulley wheel instantly ungrooves and the teeth and grooves don't align which causes our robot to jump. It is only in our right tread and the left tread is perfect. Are any other teams having this issue?
Unread 22-02-2016, 22:52
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
Re: Team 5720 Rhino Tracks Problems
It sounds like you have the tension on the belt too loose. In the instructions we give an example of what we feel the appropriate tension should be. Also, I would double check the spacers and pulley alignment down the side of the track. If one of the pulleys is being forced into misalignment it could cause it to try to ride up the V on the belt and jump the pulley.
Alumnus of FLL 2000 ~ Alumnus of FRC173 2002-2005 ~ Mentor of FRC173 2006-2007 ~ Mentor of FRC 3780 2014
FIRST Volunteer since 2003
Manufacturing Manager
AndyMark, Inc.
http://www.andymark.com
