Go to Post Those poor suckers on the West coast get three hours LESS sleep than we do afterward. Anyone else glad to see that crate go every year, regardless of what's in it? - Rich Kressly [more]
Unread 22-02-2016, 21:19
josephno1's Avatar
josephno1 josephno1 is offline
FRC #3647
Rookie Year: 2015
josephno1 is an unknown quantity at this point
ADIS16448 reading y values
Alright so I have downloaded this file
https://github.com/juchong/ADIS16448...16448_IMU.java
Anyways I want to access the method
Code:
  public synchronized double getAngleY() {
    return m_integ_gyro_y;
So in my Robot.java file I added the line
Code:
SmartDashboard.putNumber("IMU",imu.getAngleY());
Here the except of the code where that is from
Code:
package org.usfirst.frc.team3647.robot;
import edu.wpi.first.wpilibj.BuiltInAccelerometer;
import edu.wpi.first.wpilibj.Compressor;
//import edu.wpi.first.wpilibj.DriverStation;
//import edu.wpi.first.wpilibj.CANTalon;
import edu.wpi.first.wpilibj.command.Command;
import edu.wpi.first.wpilibj.smartdashboard.SendableChooser;
import edu.wpi.first.wpilibj.command.Scheduler;
import edu.wpi.first.wpilibj.smartdashboard.*;
import org.usfirst.frc.team3647.auto.*;
import org.usfirst.frc.team3647.subsystems.ADIS16448_IMU;
//import edu.wpi.first.wpilibj.Joystick;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the IterativeRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
	public static boolean shootTest = false;
	public static boolean shootTest1 = false;
	Compressor c = new Compressor();
	private BuiltInAccelerometer accel = new BuiltInAccelerometer();
	ADIS16448_IMU imu=new ADIS16448_IMU();
	Command autonomousCommand;
	SendableChooser autoChooser;
	 * This function is run when the robot is first started up and should be
	 * used for any initialization code.
	public void robotInit() {
		updateDashboard();
    	autoChooser = new SendableChooser();
    	autoChooser.addDefault("Default Autonomous", new Default());
    	SmartDashboard.putData("Autonomous mode chooser", autoChooser);
    	System.out.println("The Robot is ready");
	 * This function is called periodically during autonomous
	 public void autonomousInit(){
	    	//resetAndDisableSystems();
	    	autonomousCommand = (Command) autoChooser.getSelected();
	    	autonomousCommand.start();
		Scheduler.getInstance().run();
    	updateDashboard();
	 * This function is called periodically during operator control
		// resetAndDisable();
		updateDashboard();
		LogitechJoystick.controllers();
		Drivetrain.arcadeDrive();
		ShooterAngleMotor.angleShooter();
		BallShooter.shootBalls();
	 * This function is called periodically during test mode
	public void testPeriodic() {
	public void resetAndDisable() {
		// BallShooter.LShooter.set(0);
		BallShooter.rShooter.set(0);
		ShooterAngleMotor.angle.set(0);
		// Piston.BallShooterPiston.set(0);
	public void updateDashboard() {
		SmartDashboard.putData("IMUs", imu);
		imu.updateTable();
		System.out.println(imu.getAngleY());
