Go to Post I would rather Andy Baker be at champs than Will.i.am. - Grim Tuesday [more]
Unread 02-22-2016, 10:37 PM
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Sending video from coprocessor to Dashboard
Currently, we have the Microsoft LifeCam plugged into a Kangaroo that is running the LabVIEW vision example. Is there any way to then send the video back to the dashboard so the drivers can see the stream too?
Thanks!
I'm right 90% of the time, so why worry about the other 3%?
Unread 02-23-2016, 07:16 AM
Re: Sending video from coprocessor to Dashboard
The robot code does this using the Camera Background Loop VI. You can place it on your coprocessor if you like. But if you run more than one of these, they are using the same port and will make a mess.
Greg McKaskle
Unread 02-23-2016, 08:29 AM
Cecil's Avatar
AKA: Alex Hummel
Awesome! We will give it a try! We are only using the single camera, so we shouldn't have a problem using the same port. I will remove the vision code from the robot program and just use the coprocessor loop.
Thanks!
