Go to Post I think Baker has lost it. - Andy Baker [more]
Unread 22-02-2016, 23:44
Phil De Jong Phil De Jong is offline
FRC #5078
Phil De Jong is an unknown quantity at this point
Help with Talon SRX - CTR magnetic encoder issue
We are trying to run the Talon SRX with position control loop using a CTR magnetic encoder as the feedback device. However when we run the loop then selected encoder is not updating with new values in the web interface but just stays at 0 despite the fact that the magnetic encoder shown just below it on the web interface is working(see picture to get what I mean). I am not sure if we are just not calling out the encoder properly in our code but I have attached attached the subsystem we are using in our code to pivot the arm into one of three positions.
Any help would be greatly appreciated! Thanks in advance.
Name:	talon output.png
ID:	20158  Click image for larger version
Unread 23-02-2016, 02:14
ozrien's Avatar
ozrien ozrien is online now
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Re: Help with Talon SRX - CTR magnetic encoder issue
Update the Talon SRX firmware to 2.0.
Unread 23-02-2016, 13:10
FRC #5078
Thank you very much that worked. I thought we had updated the firmware already but I guess not...
