Go to Post Actually there are several Wayne Cokeleys circulating around. We cloned him in 2001. This is his evil twin Mordechai responding.....-WC 3 - Wayne C. [more]
Unread 23-02-2016, 01:04
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
Mentor
FRC #4607 (C.I.S.)
Team Role: Coach
Rookie Year: 2012
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
If you run over a ball...
edit: Sorry, BOULDER...
If you are in possession of a boulder and then run over another boulder, does it mean that you created a foul as per 3.4.9 G38?
"An error does not become a mistake until you refuse to correct it" ~JFK
Unread 23-02-2016, 01:07
Mentor
FRC #4607 (C.I.S.)
Team Role: Coach
Rookie Year: 2012
Re: If you run over a ball...
From what I saw at the Week Zero event that I was at, a lot of robots 'trapped' a boulder when they ran it over. Does this constitute trapping or herding?
This is pretty ambiguous a rule - and I hate for my team to be in violation of more than one rule each season...
Unread 23-02-2016, 03:43
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
IMHO, it depends upon how long you are on the Boulder. If you get stuck on the Boulder, then that is a problem.
Unread 23-02-2016, 08:21
adam the great's Avatar
adam the great adam the great is offline
Strategy Mentor
AKA: Adam Brewster
FRC #2168 (Aluminum Falcons)
Rookie Year: 2007
adam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud of
Thumbs up Re: If you run over a ball...
Typically in past years referee's generally give you a reasonable chance to avoid being called. So if you have a ball and drive over another one by accident and you immediately reverse and kick it out from under you, typically that would just be inconsequential and not called (unless repeated). But if you have a ball and this second ball gets stuck under you and takes more than around 4-5 seconds of actively trying to get rid of it, you'll likely get a penalty.
That said... its in your best interest that if you are a team that has worries about the potential of a second ball getting lodged under you ever, that you just make sure your drivers are very clear that they should avoid even contacting a second ball while you are in possession of another one. Its unfortunate if it happens, but it will happen and will likely be called many times this year so take the necessary precautions when competing and try to avoid being the team that causes your alliance to shake their heads at an avoidable foul.
~Adam Brewster~
2168 (Drive Coach/Strategist)
Past Teams: 1930, 2228, 229, 4124, 5240#NeverForget4124
