Go to Post There is a big difference between "we have not been able to figure out how to do it." and "it's impossible" or "don't even bother." Let's be constructive not discouraging. - PVCMike [more]
Unread 23-02-2016, 06:55
olidem123 olidem123 is offline
Not a community manager
AKA: Olivier Demers
FRC #5618 (PLS)
Team Role: Leadership
Rookie Year: 2015
olidem123 is an unknown quantity at this point
Question Is robot drive really important?
Hello fellows programmers,
I just wanted to know if this error is really important:
Code:
 Error at java.lang.Thread.run(Thread.java:745): Robot Drive... Output not updated often enough. ERROR  1  Robot Drive... Output not updated often enough.  java.lang.Thread.run(Thread.java:745)
I should probably put you more into context; when we hold a button, the robot drives forward by itself.
We only get this error message when we hold the button in question.
Unread 23-02-2016, 07:04
weaversam8 weaversam8 is offline
Team Captain
AKA: Sam Weaver
FRC #4534 (Wired Wizards)
Rookie Year: 2014
weaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to behold
The error "Robot Drive... Output not updated often enough." signifies that the robot is expecting to receive joystick values frequently, and is not. This is a safety measure to ensure that if a joystick fails for some reason, the robot knows about it.
This is probably happening because you have sent the signal to the drivetrain once when the button is pressed, and then you do not keep sending it signals. The drivetrain has a method around this: if you call the method "setSafetyEnabled" and pass it a value of false, it will no longer check for this constant input, which can be useful for autonomous. Be advised, however, that the robot will also not zero the outputs if a joystick fails... I suggest you only disable the safety during autonomous routines, and reenable it when you're done.
Wouldn't it be better if we just ended all of our sentences like programmers;
Unread 23-02-2016, 07:08
AKA: Olivier Demers
FRC #5618 (PLS)
Rookie Year: 2015
Smile Re: Is robot drive really important?
Thank you very much;
