Go to Post Publishing your code and designs = good. - MrRoboSteve [more]
Unread 23-02-2016, 08:22
joeojazz joeojazz is offline
FRC #5712
joeojazz is an unknown quantity at this point
Encoder Problems
Hi can anyone help with encoder code we are using java and can't seem to receive any variables back from them.
Thanks
Unread 23-02-2016, 10:19
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
FRC #2168 (The Aluminum Falcons)
otherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to behold
Re: Encoder Problems
What type of encoder (model #) are you using?
How have you wired it up to the roboRIO?
Can you provide a copy of your code so we can check it?
Have you tried following the java encoder code example here?: https://wpilib.screenstepslive.com/s...or-other-shaft
http://team2168.org
Pratik Kunapuli's Avatar
Pratik Kunapuli Pratik Kunapuli is offline
Probably browning-out on Astro-Turf
FRC #1648 (G3 Robotics)(EWCP)
Rookie Year: 2012
Pratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to all
Thanks
Can you give more details as to what encoder you are using, how it is wired, and what your code looks like?
Official Driving Record: 101-59-0
2012-2015 Student 341 Miss Daisy
2015-Current Mentor 1648 G3 Robotics
Unread 23-02-2016, 10:33
marshall's Avatar
marshall marshall is offline
My pants are louder than yours.
FRC #0900 (The Zebracorns)
marshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond repute
Thanks
Got 99 problems and quadrature is 1, no wait... 2 of them?
-Check wiring
-Check the encoder
-Hook up a scope to the lines and see if you get the response you expect
-Check your code, are you calling on the right variables? Are they changing as expected? Is anything being overwritten or called incorrectly? Perhaps you could share a snippet of your code to help with debugging.
"La mejor salsa del mundo es la hambre" - Miguel de Cervantes
"The future is unwritten" - Joe Strummer
"Simplify, then add lightness" - Colin Chapman
Unread 23-02-2016, 10:38
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
The more effort you put into providing detailed information, the more likely you are to receive quick and accurate advice.
What are you using the encoder for? To measure speed, or distance, or both? Drivetrain? Shooter wheelspeed control?
What motor controller are you using, and do you have the encoder wired to the roboRIO or to the motor controller (TalonSRX)?
Unread 23-02-2016, 14:49
FRC #5712
Sorry for the lack of information.
We are trying to use encoders attached to the sonic shifter from AndyMark.
Sonic Shifter:
http://www.andymark.com/Sonic-Shifte...nicoptions.htm
And the encoder being used with the sonic shifter is the am-3132:
http://www.andymark.com/product-p/am-3132.htm
We have them wired from the encoder into the RoboRio's DIO ports. Each encoder requires two ports because they each have 2 signal channels (A and B).
Code:
package org.usfirst.frc.team5712.robot;
import com.kauailabs.navx_mxp.AHRS;
import com.ni.vision.NIVision.Image;
import edu.wpi.first.wpilibj.CameraServer;
import edu.wpi.first.wpilibj.CounterBase;
import edu.wpi.first.wpilibj.CounterBase.EncodingType;
import edu.wpi.first.wpilibj.Encoder;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SerialPort;
import edu.wpi.first.wpilibj.VictorSP;
import edu.wpi.first.wpilibj.command.Scheduler;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
import edu.wpi.first.wpilibj.smartdashboard.SendableChooser;
import edu.wpi.first.wpilibj.Servo;
import edu.wpi.first.wpilibj.Timer;
 * @author Phillip Spannagel
	Joystick driveStick;
	CameraServer forwardCam, reverseCam;
	VictorSP leftFront, leftRear, rightFront, rightRear, shooterR, shooterL, armLift;
	Servo servo;
	RobotDrive drive;
	SerialPort serial_port;
	SendableChooser autonomous;
	AHRS gyro;
	Encoder encoderLeft, encoderRight, encoderLift;
	double angle;
	int tickGoal = 15 * 24;
	int shootCount = 0;
	int autoLoopCounter = 0;
	public void robotInit() {
		driveStick = new Joystick(0);
		leftFront = new VictorSP(0);
		leftRear = new VictorSP(1);
		rightFront = new VictorSP(2);
		rightRear = new VictorSP(3);
		shooterL = new VictorSP(4);
		shooterR = new VictorSP(5);
		armLift = new VictorSP(6);
		servo = new Servo(7);
		drive = new RobotDrive(leftFront, leftRear, rightFront, rightRear);
		serial_port = new SerialPort(57600, SerialPort.Port.kMXP);
		byte update_rate_hz = 50;
		gyro = new AHRS(serial_port, update_rate_hz);
		gyro.resetDisplacement();
		encoderRight = new Encoder(0, 1, false, Encoder.EncodingType.k4X);
		encoderRight.setDistancePerPulse(1);
		encoderRight.setMaxPeriod(.1);
		encoderRight.setMinRate(10);
		encoderRight.setSamplesToAverage(7);
		encoderLeft = new Encoder(2, 3, false, Encoder.EncodingType.k4X);
		encoderLeft.setDistancePerPulse(1);
		encoderLeft.setMaxPeriod(.1);
		encoderLeft.setMinRate(10);
		encoderLeft.setSamplesToAverage(7);
		encoderLift = new Encoder(4, 5, false, Encoder.EncodingType.k4X);
		encoderLift.setDistancePerPulse(1);
		forwardCam = CameraServer.getInstance();
		reverseCam = CameraServer.getInstance();
		forwardCam.setQuality(50);
		reverseCam.setQuality(50);
		forwardCam.startAutomaticCapture();
		reverseCam.startAutomaticCapture();
		// drive.setInvertedMotor(RobotDrive.MotorType.kFrontLeft, true);
		// drive.setInvertedMotor(RobotDrive.MotorType.kFrontRight, true);
		// drive.setInvertedMotor(RobotDrive.MotorType.kRearLeft, true);
		// drive.setInvertedMotor(RobotDrive.MotorType.kRearRight, true);
		//start = true;
		gyro.zeroYaw();
		servo.setAngle(180);
		encoderLeft.reset();
		encoderRight.reset();
		angle = gyro.getYaw();
		if (autoLoopCounter < 500) {
			drive.drive(-0.3, 0.0);//start moving
			// gyro drive "straight"
			if (angle < -2)
				rightFront.set(-0.5);
				rightRear.set(-0.5);
			if (angle > 2)
				leftFront.set(-0.5);
				leftRear.set(-0.5);
			else if (autoLoopCounter == 500)
				drive.drive(0, 0);
				gyro.zeroYaw();
			else if (autoLoopCounter < 700)
					leftFront.set(-.3);
					leftRear.set(-.3);
					rightFront.set(.3);
					rightRear.set(.3);
					if(gyro.getYaw() > -145 && gyro.getYaw() < -150) {
						leftFront.set(0);
						leftRear.set(0);
						rightFront.set(0);
						rightRear.set(0);
		autoLoopCounter++;
		SmartDashboard.putNumber("Yaw", gyro.getYaw());
		SmartDashboard.putNumber("Servo Angle", servo.getAngle());
		 * SmartDashboard.putNumber("Count (Left)", encoderLeft.get());
		 * SmartDashboard.putNumber("Count (Right)", encoderRight.get());
		 * SmartDashboard.putNumber("Distance (Left)",
		 * encoderLeft.getDistance()); SmartDashboard.putNumber("Raw (Left)",
		 * encoderLeft.getRaw()); SmartDashboard.putNumber("Rate (Left)",
		 * encoderLeft.getRate());
		 * SmartDashboard.putNumber("Distance (Right)",
		 * encoderRight.getDistance()); SmartDashboard.putNumber("Raw (Right)",
		 * encoderRight.getRaw()); SmartDashboard.putNumber("Rate (Right)",
		 * encoderRight.getRate());
		SmartDashboard.putNumber("encoder (Lift)", encoderLift.get());
		drive.arcadeDrive(driveStick);
		if (driveStick.getRawButton(1) == true) {
			shooterL.set(1.0);
			shooterR.set(-1.0);
			servo.setAngle(90);
			shootCount++;
			if (shootCount > 50) {
				shooterL.set(0);
				shooterR.set(0);
				shootCount = 0;
		if (driveStick.getRawButton(1) == false && shootCount != 0) {
			shootCount = 1;
		// set servo angle
		if (driveStick.getRawButton(8) == true) {
		if (driveStick.getRawButton(9) == true) {
			servo.setAngle(30);
		// intake
		if (driveStick.getRawButton(2) == true) {
			shooterL.set(-.6);
			shooterR.set(.6);
		} else if (driveStick.getRawButton(2) == false) {
			shooterL.set(0);
			shooterR.set(0);
		// raise and lower shooting arm
		if (driveStick.getRawButton(3) == true) {
			armLift.set(.5);
		} else if (driveStick.getRawButton(4) == true) {
			armLift.set(-.5);
		} else if (driveStick.getRawButton(3) == false) {
			armLift.set(0);
	public void testPeriodic() {
		/*if(start = true){
		if(angle < 180)
			leftFront.set(.5);
			leftRear.set(.5);
			rightRear.set(-.5);
		else if(angle == 180)
			leftFront.set(0);
			leftRear.set(0);
			rightRear.set(0);
			rightFront.set(0);
		if(angle == 180){
			start = false;
	if(start = false){
			gyro.zeroYaw();
I included all of our code. Please let me know if you need any more information.
Unread 23-02-2016, 15:52
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
This looks suspicious:
Code:
	// Encoder encoderLeft, encoderRight,
Doesn't the encoderRight = new Encoder(); line give you an error because encoderRight isn't defined?
Unread 23-02-2016, 15:59
otherguy's Avatar
sparkE
AKA: James
Yea, I agree with Alan. This code shouldn't even compile.
Code:
//Encoder encoderLeft, encoderRight
Shouldn't be commented out.
http://team2168.org
Unread 23-02-2016, 16:24
FRC #5712
We had commented sections of the encoder code that were not working. Before I pasted the code on here I attempted to un-comment everything, but it seems I forgot a couple lines.
Sorry everybody.
Unread 23-02-2016, 16:25
FRC #5712
Even when the code was un-commented we still were not receiving values. I edited the code, so it should be able to compile now.
Unread 23-02-2016, 20:16
Rookie Year: 2012
The E4T encoder has a very specific installation process, especially when interfacing with the AndyMark gearbox. I would make sure that the disk for the encoder is the correct distance away from the sensor (by using the spacing tool), as I've seen incorrect installations return no values.
Unread 23-02-2016, 23:19
otherguy's Avatar
sparkE
AKA: James
If you put a meter between find and channel A and B, you should be able to see the logic levels change as the wheel turns.
If you can measure this, the encoder is working properly and its either a wiring or code problem.
If you don't get fluctuating values on the meter, then its likely that the disk within the encoder isn't installed correctly per Pratiks suggestion
http://team2168.org
Unread 27-02-2016, 14:47
otherguy's Avatar
sparkE
AKA: James
Find = Ground. Autocorrect...
...Put a meter between ground and channel A or B...
http://team2168.org
