Go to Post Or use an IFI control system and you won't have to wait 2 minutes to use your bathroom :P - Chris is me [more]
Unread 23-02-2016, 11:55
King Nerd III's Avatar
King Nerd III King Nerd III is offline
Chief Programmer/Head of Autonomous
AKA: Isaac
FRC #1410 (The Kraken)
Rookie Year: 2014
King Nerd III is an unknown quantity at this point
Commands Ending Other Commands
I have a commands that runs the rollers outwards and a command that runs the rollers inwards, but if one is running and you call the other one (through pressing a button), then both commands attempt to run at the same time. Is there any way to have each command end the other one when called?
I had an idea where you declare a Command object in the command of the other command (i.e. Inwards has an Outwards Command object in it) and when one is initialized it calls End() from the object, but I don't know if that would work, and don't have the robot electronics board with me to test right now. Any ideas?
Isaac
Chief of Programming and Head of Autonomous Control
FRC Team 1410
Unread 23-02-2016, 12:17
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Commands Ending Other Commands
Make them both call Requires(YourRollerSubsystem) and SetInterruptible(true) in the constructor. Wpilib will then take care of ending the running one when the other is called for you.
Unread 23-02-2016, 13:15
AKA: Isaac
Rookie Year: 2014
Thanks. I knew about the Requires, but I had no clue SetInterruptible was a thing. I'll add that in now.
Isaac
FRC Team 1410
Unread 23-02-2016, 14:17
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
interruptable is true by default.
Unread 23-02-2016, 14:49
AKA: Isaac
Rookie Year: 2014
I thought that was the case, but calling a command that requires the same subsystem doesn't interrupt the original command for us. Any clue on how to fix this?
Isaac
FRC Team 1410
Unread 24-02-2016, 13:31
Waz Waz is offline
Strategy and programming mentor
AKA: Steve
FRC #2357 (System Meltdown)
Waz is an unknown quantity at this point
We have never had a problem with this in several years of using the command based programming model. Is it possible that you have accidentally created two instances of the subsystem and the two commands each have their own? That could cause this behavior.
Hope this helps,
Steve
