Go to Post 254 isn't just good at building their robot. They're also good at taking pictures of it. - Chickenonastick [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 23-02-2016, 15:51
jakobgilbert jakobgilbert is offline
FRC #2872
jakobgilbert is an unknown quantity at this point
Angry Robot stopped communicating with one day left...
My robot emits a WiFi Signal with my team number as the name, yet when I connect the robot has no communications. I have tried EVERYTHING, resetting RoboRio, the computer, the router. The router I'm using is the small white new one that came in the kit. It keeps saying there's more info in the diagnostics, but it's blank. I'm freaking out, this is the last day and we essentially have 3 hours to fix an unprecedented error that began between us leaving yesterday and coming in today, with no change in between. PLEASE HELP!
Unread 23-02-2016, 15:53
hardcopi hardcopi is offline
AKA: Rich Lester
FRC #2959 (The Robotarians)
Rookie Year: 2013
hardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud of
Re: Robot stopped communicating with one day left...
Can you connect via ethernet? If you can connect via ethernet then it is likely the router which is the issue.
Unread 23-02-2016, 16:02
FRC #2872
Just tried ethernet. No connection.
Unread 23-02-2016, 16:04
jajabinx124's Avatar
jajabinx124 jajabinx124 is offline
Team 2052 Alumni
AKA: Kshitij Wavre
Rookie Year: 2013
jajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond repute
Can you connect to the RoboRio via Ethernet and get comms? (this way you know at least the roborio works and the router is the only issue.. rather find that out too)
FRC Volunteer CSA (MRI off-season event, 2017 Lake Superior Regional, 2017 10,000 Lakes Regional) 2016 - Present
FRC 2052 KnightKrawler (Team Captain, Strategist, Scouting, Programming) 2013 - 2016
1 Division Win & Einstein Appearance
3 Division Quarter-Finalists
1 Regional Chairman's Award
5 Regional Wins, 3 Regional Finalists
3 MN State Championship Wins, 1 MN State Championship Finalist
Thanks to all our alliance partners who krawled with us: 41, 70, 225, 525, 1595, 2054, 2062, 2122, 2175, 2227, 2472, 2526, 2883, 2990, 3018, 3244, 3276, 3310, 3313, 3360, 3538, 3692, 4011, 4198, 4536, 4607, 4778, 5172, 5690
Unread 23-02-2016, 16:08
edong4273's Avatar
edong4273 edong4273 is offline
Team 2375's Very Own Dong
AKA: Edmund "Dong" Dong
FRC #2375 (Dragon Robotics)
Rookie Year: 2015
edong4273 is on a distinguished road
As hardcopi said, you should also try connecting to the RoboRIO via a ethernet cable or a USB cable (Note: Only the USB type-b connection (the square USB connector) works for connecting the RoboRIO to a driver station).
If all else fails, what I had to do when the RoboRIO on out practice bot wouldn't cooperate, a simple reformat of the RoboRIO usually does the trick.
Also, if possible, try to see if connections work on a separate computer that has the correct programs installed as well.
Unread 23-02-2016, 16:13
SteveGarward's Avatar
SteveGarward SteveGarward is offline
Red 5, standing by...
AKA: 7 years already
FRC #0111 (WildStang), FRC #3132 (Thunder Down Under)
Rookie Year: 2010
SteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud of
Try USB to connect to the robot from your computer. We had a RIO where the Ethernet port died completely in the middle of running the robot. No network lights, nothing. USB worked though. Ended up returning/replacing the RIO. But USB is a good way to see if it's isolated to just the network port.
FRC Team 111 - WildStang (Mentor, Drive Coach)
FTC Team 7458 - Full Force! (Mentor, Coach)
FRC Team 3132 - Australia's FIRST FRC Team! (Holy crazy first year, Batman!)
