Go to Post Never Underestimate the power of zip ties! - tonyargote [more]
Unread 23-02-2016, 18:37
Rocinante Rocinante is offline
FRC #1994
Rocinante is an unknown quantity at this point
Autonomous Timer Issue
I am having problems with the timer for our autonomous code in iterative command based java.
We can get our first addSequential command to run in our autonomous group but it will not stop.
Here is what we did to try to call a timer for our autonomous command group:
public static double getFPGATimestamp() {
return 0;
Does anybody have any ideas how to call a timer to test our code?
Thank you for any information you may offer.
Last edited by Rocinante : 23-02-2016 at 18:41. Reason: Did not include "command based java".
Unread 23-02-2016, 23:23
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
FRC #1684 (The Chimeras) (5460 Mentor)
Rookie Year: 2013
Arhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to behold
Re: Autonomous Timer Issue
I'm sorry I'm tired but going off of this bit of text
i think you want to put a
Code:
setTimeout(timeToPause)
in your initialize() method of the command (not command group) (though I think you can set the timeout from the command group too? just do like
Code:
AutonCommand c = new AutonCommand()
c.setTimeout(1)
addSequential(c)
if i remember correctly.
FRC Team 1684 - Head Programmer (2013-2016)
FRC Team 5460 - Programming Mentor (2015-2016)
FIRST in Michigan - Technical Crew (2015-continuing)
Unread 24-02-2016, 10:04
FRC #1994
Cool, thank you we will give it a shot.
Unread 24-02-2016, 13:43
Waz Waz is offline
Strategy and programming mentor
AKA: Steve
FRC #2357 (System Meltdown)
Waz is an unknown quantity at this point
Also working from fuzzy memory, but I think you will need to call something like isTimedOut() in your isFinished() method and return true or false appropriately. If I recall correctly, setting a timeout does not mean the command will automatically be stopped.
Hope this helps,
Steve
Unread 25-02-2016, 15:34
FRC #1994
Here is our code as of bagging up the robot. We cannot get it to move to the next steps of ArmDown, Turn. and Shoot. It just keep driving forward. If we switch code around whatever is in the top slot just keeps going on and on. So we are attaching to the code however the code does not seem to attach to a timer. So trying to attach a timer.
Public classAutonomous extends CommandGroup
return 0;
public Autonomous() {
requires(Robot.drivetrain);
requires(Robot.robotshooter);
requires(Robot.armstart);
addSequential(new DriveForward(3.0));
addParallel(new ArmDown());
addSequential(new Turn(2.0));
addSequential(new Shoot(2.0));
Last edited by Rocinante : 25-02-2016 at 15:46. Reason: Forgot a line of code that could be helpful.
Unread 25-02-2016, 16:58
pblankenbaker pblankenbaker is offline
FRC #0868
pblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of light
I did not see the source for your DriveForward command. I'm guessing it should look something like the following:
Code:
public class DriveForward extends Command {
	private double timeToRun;
	public DriveForward(double timeout) {
		timeToRun = timeout;
	@Override
	protected void initialize() {
	@Override
	protected void execute() {
		// Change to method to apply power to your drivetrain
		drivetrain.setPower(0.4, 0.4);
	@Override
	protected boolean isFinished() {
		return (timeSinceInitialized() >= timeout);
	@Override
	protected void end() {
		// Don't forget to stop
		drivetrain.setPower(0, 0);
	@Override
	protected void interrupted() {
		end();
Is it possible that your isFinished() implementation was not checking that enough time had elapsed? If your isFinished() never returns true and you don't set a time out to interrupt your DriveCommand, the command will never stop and your robot will just keep going forward (which sounds like the condition you were describing).
Also, don't forget to stop the motors in your end() and interrupted() methods - unless you want the robot to continue to move even after the command terminates.
Unread 26-02-2016, 16:27
FRC #1994
So you are putting the timer in the Drive Forward code not the Autonomous code. I have seen several ways. I think I like this one best. I will give it a shot. Thank you very much.
