Go to Post As long as this is a competition teams will push the limits. Those that succeed are those who can push the envelope and still stay within the lines. - Steve W [more]
Unread 23-02-2016, 19:24
Railbots Railbots is offline
FRC #6029
Railbots is an unknown quantity at this point
Help programming our robotic arm
Our programming team is currently working on trying to get our arms program done while our mechanical team finishes attaching the arm to the base but we aren't sure what we're doing wrong or if we're doing the right thing. We would greatly appreciate help getting the code up and running. We used this webpage we found to get to this point.
ID:	20170  Click image for larger version
Unread 23-02-2016, 19:59
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Help programming our robotic arm
The code in Begin.vi on the left that you've taken is old and some of it is done a little differently.
Just Open a Servo like you would normally.
In your block diagram just delete all the constants you have there now.
Left-click on the PWM Channel input node and select Create->Constant to get your PWM constant. Then set it to the PWM you want.
I'd leave the Angular Range (170) off and just let it default.
Double check that the joystick axis (3) is the one you want to be using.
