Go to Post As a Mississippi boy, I'm especially proud that I could read - Natchez [more]
Unread 23-02-2016, 21:32
szsz9 szsz9 is offline
FRC #6000
szsz9 is an unknown quantity at this point
How to pause GRIP data input?
We are using GRIP for our image processing and we need to grab the information of a single contour. Currently it is not possible for us to eliminate all other contours, so instead we are using the largest contour to determine what the goal is.
We are currently finding the position of the largest contour in the array and finding that number value in another array (like center x, or height). This doesn't work because the smaller contours fluctuate a lot and the position of the goal/largest contour changes from the first time we get the data (area) to the second time we get the data (centerX, or height).
Is there any way to pause the input from the Network Tables? Or can we take a picture using the webcam and just analyze the picture?
Thanks
Unread 23-02-2016, 22:45
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
Re: How to pause GRIP data input?
This feature hasn't been documented yet, but yes, you can pause GRIP using NetworkTables if you're using the very latest release candidate (v1.3-rc1).
Code:
NetworkTable table = NetworkTable.getTable("GRIP");
table.putBoolean("run", false); // Stop GRIP without killing the process
doSomeStuffThatDoesntNeedVision();
table.putBoolean("run", true); // Start GRIP again
This should work if you just want to process a "snapshot" of the input, but keep in mind that there's always a little latency with NetworkTables updates, so you can't precisely control when GRIP starts and stops.
The latest NetworkTables protocol supports RPC "transactions", which should help fix this, but currently there's still work to be done in bringing support for this feature to the Java bindings.
GRIP (Graphically Represented Image Processing) - rapidly develop computer vision algorithms for FRC
Unread 23-02-2016, 23:14
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
FRC #1684 (The Chimeras) (5460 Mentor)
Rookie Year: 2013
Arhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to behold
You could just flash the data immediately... something like how I do ours
Code:
        self.rotateError = 0
        try:
            beta = self._getArray("area")
            x = self._getArray("centerX")
            y = self._getArray("centerY")
            self.largestArea = 0
            self.largestIndex = -1
            for index in range(len(beta)):
                if beta[index] > self.largestArea:
                    self.largestIndex = index
                    self.largestArea = beta[index]
            if self.largestIndex != -1:
                wpilib.SmartDashboard.putNumber("Largest Area", beta[self.largestIndex])
                wpilib.SmartDashboard.putNumber("Largest x", x[self.largestIndex])
                wpilib.SmartDashboard.putNumber("Largest y", y[self.largestIndex])
                wpilib.SmartDashboard.putNumber("X Error", self.center_x - x[self.largestIndex])
                wpilib.SmartDashboard.putNumber("Rotate Error", self.degrees_per_x_error * (self.center_x - x[self.largestIndex]))
                wpilib.SmartDashboard.putNumber("Y Error", self.center_y - y[self.largestIndex])
                self.rotateError = self.degrees_per_x_error * (self.center_x - x[self.largestIndex])
                self.y = y[self.largestIndex]
            return
        except KeyError:
            return
        except IndexError:
            return
FRC Team 1684 - Head Programmer (2013-2016)
FRC Team 5460 - Programming Mentor (2015-2016)
FIRST in Michigan - Technical Crew (2015-continuing)
Unread 27-02-2016, 11:43
s-taylor s-taylor is offline
Scott Taylor
FRC #1735 (Green Reapers)
Rookie Year: 2014
s-taylor has a spectacular aura abouts-taylor has a spectacular aura about
In our testing of the system, we have seen the noise coming fast enough that successive calls to getArray() return different sized arrays (meaning the table updated asynchronously in the two cycles between the getArray() calls)
For now, I have solved this by checking the array size for all the elements, and if there is a mismatch I just punt that dataset. Even that isn't perfect because the array could have updated but be different sizes... but it's as close as I can get without an atomic operation.
