Go to Post If you are old then our lead mentor is ancient. Oh wait, he is. Oh wait, that makes me ancienter. - JaneYoung [more]
Unread 24-02-2016, 04:47
techhelpbb's Avatar
techhelpbb techhelpbb is offline
FRC #0011 (MORT - Team 11)
Rookie Year: 1997
techhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond repute
Least expensive solenoids
As I round out my Makerspace test robots I find the last thing I need to collect are some FRC legal pneumatic parts to finish up a pneumatic accessory board to swap back and forth between the: 8 slot cRIO, the 4 slot cRIO and the RoboRIO robot control systems. I have a lot of pneumatic pieces laying about from nonFRC automation projects and some soft robotics work that might work but probably aren't FRC practical. However I've never been the one buying FRC pneumatic parts for FRC11/193. I understand the minimum requirements in the manuals past and present. I grabbed up a compressor, 2 tanks and some fittings from AndyMark's Deal-of-The-Day yesterday.
I am wondering if anyone has any tips for decent cheap solenoid valves? I know AndyMark sells a pretty broad selection but as this is more a demo than anything with actual requirements I just want stuff that would be FRC legal and practical.
Unread 24-02-2016, 09:31
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
Rookie Year: 2010
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
Re: Least expensive solenoids
Though I haven't used them in competition yet, this year we bought pneumatic solenoid valves from www.automationdirect.com and they were by far a better price than festos from andymark. The five-port AVS-5211-24D (24 volt) is like $22 compared to festo am-0888 at $119. A-d also sent a $30 coupon in the KOP. Note that the a-d valve is significantly larger in size than the festo.
Unread 24-02-2016, 10:28
ZamericaZ's Avatar
ZamericaZ ZamericaZ is offline
AKA: Eric Mazza
FRC #0503 (Froge Force)
Team Role: Operator
Rookie Year: 2012
ZamericaZ is an unknown quantity at this point
We've been using the SMC base mount and solenoid valves ( sold here by vex ) the last 3 years and the only problems we've had with them is that the mount's exhaust will leak if a valve is not screwed in all the way but it's an easy fix.
With a single solenoid valve costing $50 and $70 for a double they might be more than you'd be willing to spend since it's just demoing. But if it's something you plan on using for the next few years then I'd say they are definitely worth the price as they hold up really well and don't seem to get affected much by age/usage.
Unread 24-02-2016, 11:18
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
lynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond repute
Send a message via AIM to lynca
I've ordered solenoids from amazon in the past. Before ordering, verify solenoid specifications meet FRC rules.
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 24-02-2016, 11:19
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
Agree with hrench, Automation direct is probably the cheapest place to get them. You can get a valve for < $20. which is a bargain compared to Festo or SMC valves. I've never used them though, so I can't speak to how well they work. I've inspected a lot of robots with AD valves and no one seemed to complain about them or have issues.
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
Unread 25-02-2016, 15:02
techhelpbb's Avatar
Rookie Year: 1997
Thanks everyone for the input.
Looks like I'll be buying some solenoids from Automation Direct.
Unread 25-02-2016, 16:02
Nebster's Avatar
Nebster Nebster is offline
AKA: Ben Kishter
FRC #1306 (BadgerBOTS)
Team Role: Driver
Rookie Year: 2012
Nebster is an unknown quantity at this point
Keep in mind that the AD solenoids are much bigger than the SMC ones. If that's not a problem for you, they are definitely the cheapest I've found!
2015 Wisconsin Regional Chairman's Award - Carson Division
2013 Wisconsin Regional Chairman's Award - Curie Division
