Go to Post I think FIRST is a big trap. They lure you in with these cool competitions and shiny robots and along the way they trick you into learning something :) - =Martin=Taylor= [more]
Unread 25-02-2016, 13:54
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
Re: Al's 2016 Inspection Thread
I think most of the bumper confusion is teams trying to fit the rules to their robot rather than the robot to the rules. The 2011 rules had the effect that the minimum frame segment was 6" since the minimum bumper length was 6 inches. IE no round robots. Gaps in bumpers were not allowed in 2011. I think the current rule phrasing came about from changes that allows bumper gaps & round robots. Better phrasing might be segments less than 16" require full bumpers and segment greater than 16" require 8" from each vertex since that is the effect of the current rule.
If you don't know what you should hook up then you should read a data sheet
Unread 25-02-2016, 07:16
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Originally Posted by Daniel_LaFleur View Post
Al,
Just out of curiosity, wouldn't it be less than 16" (8" from EACH of the vertices)?
R19 ROBOTS are required to use BUMPERS to protect all outside corners of the FRAME PERIMETER. For adequate protection, at least 8 in. of BUMPER must be placed on each side of each out side corner (see Figure 4-3). If a side is shorter than 8 in., the entire side must be protected by BUMPER (see Figure 4-4).
Al
WB9UVJ
www.wildstang.org
________________________
Unread 25-02-2016, 08:07
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is offline
FRC #2363
Team Role: Coach
Rookie Year: 1999
Nate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond repute
This is one of the biggest faults of the bumper rules. It's very unhelpful for R19 to repeat that the entire side <8" must be protected by BUMPER, when earlier statements make it obvious that this MUST be the case for rules-compliant bumpers with sides <16". The poorly worded statement is probably causing misinterpretations and mistakes. But unfortunately it's been repeated around FRC for so long that it might be ingrained at this point.
Unread 07-03-2016, 10:02
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
Rookie Year: 2013
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Al,
Question for you regarding the "dump" valve on pneumatic system.
Does it matter if the valve is before or after the regulator? Ie on high pressure side or low pressure side, as long as it completely vents all pressure from system.
I couldn't seem to find a rule that dictates placement. Closest I could find was R83 stating the only devices that "may" be on high side.
Unread 07-03-2016, 10:12
Unsung FIRST Hero
Rookie Year: 1996
R89 Any pressure vent plug must be:
A. connected to the pneumatic circuit such that, when manually operated, it will vent to the
atmosphere to relieve all stored pressure in a reasonable amount of time, and
B. placed on the ROBOT so that it is visible and easily accessible.
When you place it downstream from the regulator is takes longer to release all pressure so that is why most people put it upstream.
Al
WB9UVJ
www.wildstang.org
Unread 07-03-2016, 11:14
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
I noticed a discrepancy in interpretation between myself and another inspector at my event last weekend with regard to what counts as 'automotive motors' and since I will be inspecting at several more events this year I'd like a bit of clarification.
To qualify as an automotive motor, does it have to be a production part on a vehicle. In the interest of cost savings, is there any reason an aftermarket part that is intended for the same function would not be acceptable?
Are power lift gate motors considered door motors? What if these vehicles are referred to as 5 door models (hatchbacks).
If we cannot remove a COTS gearbox from the window motor, can we do so on other automotive motors? What if you could buy that motor without the gearbox? What is considered integral to the mechanical integrity of the motor?
Perhaps this would be better on Q&A, but since it doesn't really impact my team I wasn't going to request we ask it there.
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
Unread 07-03-2016, 12:27
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
Originally Posted by Q&A
Q811 Q. Hello all, we have a motor labeled as a rear gate motor, does this fall as a door motor or not? Thanks.
FRC0247 on 2016-02-12
A. No, a rear gate motor is not a door motor and thus not permitted.
So be sure to label it a rear door motor?
Unread 07-03-2016, 12:01
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
That's usually the case, but not always. If you have working-pressure accumulators, for whatever reason, it can easily take less time to release if your dump valve is on the low side of the primary regulator.
Unread 07-03-2016, 10:19
dradel's Avatar
Rookie Year: 2013
My team couldn't pass inspection due to being on low side. When the students questioned this the inspector just walked away and wouldn't listen to reading of rules or reason.
Personally I don't think it matters one way or the other, but in the name of safety it is safer on the low side in my opinion.
Unread 07-03-2016, 10:30
rsisk's Avatar
rsisk rsisk is online now
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Rookie Year: 2007
Two things would have helped the majority of teams at San Diego this year...
1. Read AND UNDERSTAND the bumper rules
2. Update your driverstation software
This is the advice I sent to all the SD teams as their LRI...
DRIVER STATION UPDATE
Team update 12 included an update to the Driver station software. Your driver station MUST be updated before you can compete in San Diego. Please update your software before you come to the competition.
https://decibel.ni.com/content/docs/DOC-46527
COST ACCOUNTING WORKSHEET
Every team must show a completed Cost Accounting Worksheet (we used to call them your Bill of Materials) in order to pass inspection. You can find a suggested format attached. Please have this filled out before you come to the competition
INSPECTION WORKSHEET
Want to get through inspection quickly? Have a look at the attached inspection checklist for the rules you must comply with before you will be allowed to compete.
BUMPERS
Make sure your bumpers are compliant with Section 4.7 Bumper Rules in the Game Manual. If you think there might be a problem, be sure to bring the appropriate material and parts to correct your bumpers at the competition. You must have legal bumpers (both red and blue) before you can compete.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 07-03-2016, 10:53
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
R89 requires the vent valve release all pressure in the system. If the regulator is set to 0 pressure, a low (working) pressure vent will not vent the high pressure (stored) side.
Unread 09-03-2016, 03:01
Unsung FIRST Hero
Rookie Year: 1996
What was "on the low side"? You have the right to call in the LRI at your event for a decision and they all have my contact info to ask about a ruling they are unsure of. If your pressure was low, was it at the output of the regulator or was the storage pressure too low? In the case of the working pressure being low, that is within the legal limits. A team can set the pressure to whatever they want as long as it does not exceed 60psi. However, many valves get flaky at lower pressure.
If the "storage pressure" was low, was the compressor turning off? If not, you had a significant leak.
Al
WB9UVJ
www.wildstang.org
Unread 09-03-2016, 08:12
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Their vent plug was on the low pressure side of the regulator.
Unread 07-03-2016, 11:40
dradel's Avatar
Rookie Year: 2013
Ok I'll bite, why would the regulator be set to zero?
My point is the rule is open to not only interpretation, but also becomes a matter of opinion. The rules don't say must or shall be on the high side, but rather says must have one.
We had one that infact did empty the system completely, he just didn't like it on the low side, and seeing as there is no rule that says must be on high side it became his opinion.
How are teams going to be able to figure out what one persons opinion is going to be?
  #15   Spotlight this post!
Unread 07-03-2016, 11:57
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
That's why teams ALWAYS have the right to appeal to the LRI. I know as an LRI, I will walk a team through any rule in question and make sure they understand why the ruling is the way it is. Most, if not all, of the other LRI's I know will do the same.
It's unfortunate, but it's practically an impossibility to properly train every inspector for every situation they may encounter when looking at a robot. I always tell my inspectors that if they aren't 100% positive about something, they need to come get me. If a team has a problem with a ruling, the inspector need to come get me. It makes it a busy day for me (50k steps during the 3 days at the Duluth regional alone!), but that's why I'm there!
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
