Go to Post Less playing to the camera, more talking about cool FIRST stuff please. - Cuog [more]
Unread 08-03-2016, 16:36
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
Rookie Year: 2013
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Thanks for all the input on this.
Unread 08-03-2016, 16:41
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
Re: Al's 2016 Inspection Thread
I submitted the question on where the vent needs to be to Q & A. It is question Q933.
If you don't know what you should hook up then you should read a data sheet
Unread 08-03-2016, 16:57
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Thanks for doing that, Frank.
When I was a Lead RI, we had weekly conference calls with the Chief. Current LRIs I know tell me they still do that now. Several of them read CD frequently, so I expect that my Lead RI for this week's event will be able to give a ruling on vent valve requirements, should that question come up while inspecting a robot.
Before hearing from my LRI, my own opinion is the same as Richard Sisk's, based on my reading of R78 and Fig. 4-15. After I hear from my LRI, that could change.
Richard Wallace
since 2003
Unread 08-03-2016, 21:54
dradel's Avatar
Rookie Year: 2013
Originally Posted by rsisk View Post
I would rule it has to be on the high pressure side based on R78.
R78 If pneumatic COMPONENTS are used, the following items are required as part of the pneumatic
circuit and must be used in accordance with this section, as illustrated in Figure 4-15.
Figure 4-15 shows the dump valve on the high pressure side of the system.
I understand where you are coming from, but it is an example. My point is if the rule doesn't explicitly say it is open for interpretation, or opinions which leads to issues.
Similarly there is no official rule on where the main breaker has to be, and for the rule book to say "strongly recommend" doesn't mean has to be.
It becomes frustrating when others don't "feel" that the breaker or dump valve aren't in the correct place. If the rules aren't going to be explicit about such things then how can teams "fail" inspection? It's kind of like trying to say something isn't art.
Unread 08-03-2016, 22:07
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Most of the inspection rules, especially those that are left to interpretation, are about safety. Make it easy on yourself and your inspector - unless you have a very specific reason, just follow the recommendations. When you deviate from recommendations, have your "plan B" figured out beforehand (e.g. the recommended part already in the pit and a plan to install it). The example here is one - what's the big problem with just putting the vent plug on the high side?
Unread 08-03-2016, 23:41
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Originally Posted by GeeTwo View Post
...what's the big problem with just putting the vent plug on the high side?
It takes noticeably longer to move air from the low-pressure side to the high-pressure side through the recommended regulator than from high to low. If there is air stored at working pressure, putting the vent on that side lets the pressure be released faster.
Unread 08-03-2016, 23:14
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
The rule on the main breaker isn't "strongly recommend".
R39 The 120A circuit breaker must be quickly accessible from the exterior of the ROBOT. This is the only 120A circuit breaker allowed on the ROBOT.
It's "must be". I will grant you that "quickly accessible" is a judgement call on the part of the inspector... But I can't think of a way to word such a rule as to remove judgement from the equation. All robots are designed differently, and a location that works on one won't work on another. The bottom line with this rule is how you want the event staff to handle your robot should it start smoking - pull out the fire extinguisher and give your electronics a dousing, or kill power quickly and safely? One way you'll likely be back on the field for your next match. The other is a huge mess.
Honestly, I've never had a problem getting a team to move their main breaker or vent plug valve to someplace more accessible. They all seem to understand the safety reasons (at least, the mentors do) for it and comply quickly and willingly.
Now, I have to ask... why is it such a big deal to have the vent plug valve on the low side? What do you get from that that other teams don't get by having theirs on the high side? Why not just hook up the pneumatics similar to figure 4-15 like everyone else to begin with? You seem to be very adamant about this, yet your robot has already been changed to have it on the high side...
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 09-03-2016, 06:07
dradel's Avatar
Rookie Year: 2013
It isn't an overly big deal at this point. I was just wanting al to say it has to be on the high side, or it doesn't matter. In all reality it doesn't make a difference where the valve is located as long as the system is emptied in a timely fashion.
Now what's a timely fashion?? Our robot has two tanks, so it takes very very little time.
As for the breaker. I was referring to the blue box about the label saying breaker here.
Unread 09-03-2016, 06:08
dradel's Avatar
Rookie Year: 2013
Originally Posted by Al Skierkiewicz View Post
What was "on the low side"? You have the right to call in the LRI at your event for a decision and they all have my contact info to ask about a ruling they are unsure of. If your pressure was low, was it at the output of the regulator or was the storage pressure too low? In the case of the working pressure being low, that is within the legal limits. A team can set the pressure to whatever they want as long as it does not exceed 60psi. However, many valves get flaky at lower pressure.
If the "storage pressure" was low, was the compressor turning off? If not, you had a significant leak.
The pressure release valve was on the low pressure side of the regulator in the system.
Unread 09-03-2016, 09:27
dradel's Avatar
Rookie Year: 2013
It just hit me that the point of it will vent faster if on the high pressure side doesn't exactly hold true. If teams were to have the accumulator tanks on the low side for whatever reason the stored air would have to flow back through the pressure regulator as well. I have seen regulators that only operate in one direction. That is to say air won't flow through from the regulated side to the supply side, which would prevent the system from being completely emptied.
Unread 09-03-2016, 09:56
The regulator is required to be relieving, per R82, for exactly that reason. When high pressure is released in this case, the low pressure side would be vented through the regulator.
Unread 09-03-2016, 10:44
Rookie Year: 1996
But the relieving regulator will stop relieving when it reaches the working pressure set point, correct?
Richard Wallace
since 2003
Last edited by Richard Wallace : 09-03-2016 at 11:32. Reason: typing too fast, with my thumbs
Unread 09-03-2016, 11:07
Software Architect
Merely being a relieving regulator wouldn't necessarily be enough. A relieving regulator vents to atmosphere when performing its "relieving" function. Every regulator I have seen on an FRC robot does let air flow in reverse when the input pressure is lower, but nothing says it must do so.
While I've never actually encountered one in the wild, I know there are regulators that don't care whether the "high side" pressure is lower than the "low side". Such a regulator would maintain the working pressure even after the stored pressure part of the system was emptied. <R89A> would make it illegal to put the vent valve on its stored pressure side even though the regulator satisfied <R82>.
Unread 10-03-2016, 04:45
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
I do want every team to know this. If you question an inspector's decision, it will not be held against you. If it does, I want to know about it. You have every right to ask the LRI at your event for ruling and to explain the rule he is using to make his decision. If there still is a question, the LRI is instructed to give me a call or text. If I cannot be reached, Jonathon Bryant should be called, and after that Frank Merrick. All the LRIs have my number and Jonathon's.
Al
WB9UVJ
www.wildstang.org
________________________
  #15   Spotlight this post!
Unread 10-03-2016, 11:08
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Thanks for this Al! I know in the past my kids have been hesitant to push back. One year at QCR the RI wanted them to completely rewire the main breaker in order to relocate it because he felt it was not easy to access. They were getting ready to start moving it, when I walked up and stopped them and asked for an explanation. He pointed out the restrictions. I agreed that it wasn't the best place, but it was protected and where he wanted it was not. Additionally his hands were giant so of course he would have problems that none of us had. I asked for the LRI to make a ruling and she simply asked us to make it more visible by placing the main breaker stickers around the location.
We were gracious and non-confrontational about it, which is the key when questioning/pushing back against what you think is within the rules.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
