Go to Post You are given a goal with some simple restrictions. That's it. No one really cares how you get it done, just the fact that you get it done. - Max Lobovsky [more]
Unread 24-02-2016, 09:27
BSV BSV is offline
FTC / FRC mentor
AKA: Travis
FRC #2723
Rookie Year: 2011
BSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud of
four-motor tank drive control
Hi all,
Our programmers are trying to set up tank drive controls and are having a hard time getting all 4 drive motors to fire simultaneously. They had it working for arcade drive, but when they switched to tank control only one of the motors on each side is firing.
We are using Talon SRXs on the CAN bus.
This document:
https://docs.google.com/document/d/1...VR0yS7cqI/edit
mentions how to fire all four motors using PWM output, but it is a couple of years old and doesn't talk about CAN.
Does anyone have a more recent example of how to make this work that I can point them towards?
Thanks!
