pic: FRC 4329 Presents Trogdor
Re: pic: FRC 4329 Presents Trogdor
What's the brake caliper for ?
Our original intake pivot used a versaplanetary gearbox to rotate. The idea was that the disc brake would help secure the Intake and hold at a desired position without the need for elastic or stalling the motor. We killed a couple of gearboxes on various defenses and decided to find a way to use pneumatics instead.
We are now looking at 3 position cylinders or to still use the disc brake to halt the motion of the cylinder depending on which position we want via an encoder. The plan is to have a retracted position, intake position and portcullis / chivel de frise position. All of this happened in the last 4 days so we just left it on for now Here's a link to a few more images - http://imgur.com/a/4Zrct ![]() Last edited by Ryan Dognaux : 24-02-2016 at 21:47. |
Looks really nice!
Are you planning to go under the portcullis? The intake looks like it is designed to, but the RoboRIO suggests otherwise. |
I dig the yellow chords. Are those the ones you connect with the inserts or did you melt them together?
We tried a MiniCIM into a 1:100 versaplanetary that was built using various stages (2 and 3). The issue wasn't really the gearbox's power, it was the way we were face mounting it using one of the versa gussets. It's generally not a great idea to have your gearbox taking lots of shock loads as you ramp the intake into the various defenses that we're planning on using it on. We want things to be extremely robust for this game so we made a decision to use pneumatics on the pivot and haven't looked back. |
Trogdor! What a great name for a robot! Why didn't I think of that? Interesting design, too! What size are those drive wheels?
We're using the black versions of the 200 x 50 mm tires from this website: http://www.mfgsupply.com/8-10428.html They're the same as the gray Andymark ones. Quote:
Very nice, looks sharp! What are your collector rollers made of? The clear plastic is pretty cool to see through, especially spotting the center bearing in the front roller. I also like how the centering belts are slaved off of the intake belts.
Also, what motor/gear combo did you have on collector lift that was giving you issues? We actually have a very similar collector (and hope to add a similar shooter later with carry-in allowance, but prioritized climbing over shooting). Our collector uses 3 separate motors though, centering, intake, and rotate up/down. Our rotate is powered by a bag CIM geared 500:1, no brake mechanism (100:1 VersaPlanetary, then VP spur gears 14:70) So far no major issues, and only one smoked motor - from stalling against a hard-stop before limits and closed-loop control were added. |
#10
PM me if you want more info/pictures All thanks go to Brian from 2791 for introducing this to me |
#11
Trogdor! The Burninator! Looks like you'll be ready to fight back against that 10th Defense.
#12
![]() P.S. The think about kicking the player station wall was a joke. Don't actually do that. Especially if you're at the middle station. |
#13
Really really digging the disk brake, I never got to see that update on facebook!
Turned out awesome Ryan! How often are you guys expecting to run practice sessions with the second bot? |
#14
![]() Once we have that completed, we should have 2 weeks of drive team practice & autonomous development for St. Louis. |
#15
With all of the cool reveal videos FUN showed tonight, we wanted to post a quick teaser of Trogdor shooting: https://youtu.be/U78u0kuxJ-A
A more full length video will get filmed this weekend using our practice robot. Looking forward to seeing everyone at the St. Louis regional! |
