Go to Post Since you have to undo all the connections anyway in order to swap them, you might as well take advantage of the opportunity to do some simple and straightforward troubleshooting. - Alan Anderson [more]
Unread 25-02-2016, 00:58
hardcopi hardcopi is offline
AKA: Rich Lester
FRC #2959 (The Robotarians)
Rookie Year: 2013
hardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud of
2nd Camera and Rasperry Pi
I see some people using the raspberry pi to process video. I am hoping someone can help me figure out if this is what I need.
I simply want a 2nd camera feed. I installed MJPG on the Roborio and it works great, provided I don't use the camera I want to. With Lifecams I can run the one on the dashboard along side the MJPG stream with no issues. However, when I switch to the 180 camera the other camera won't work. I am thinking it is a driver issue or something along those lines.
Question is, can I just run Mjpg on an raspberry pi and mount the camera on that. If I do that how do I get access to it, not wirelessly obviously.
