Go to Post Wait, I thought 2009 started on January 3rd... - ComradeNikolai [more]
Unread 25-02-2016, 14:45
alambert14's Avatar
alambert14 alambert14 is offline
Student Programmer
AKA: Abby Lambert
FRC #2035 ("Rockin" Bots)
Rookie Year: 2014
alambert14 is an unknown quantity at this point
Unhappy Code Not Recognizing Second PCM
I asked a question on here a while ago asking how to wire multiple PCMs, and I wired in in the can bus in series exactly how people said. As I can see on the roboRIO system configuration, the roboRIO recognizes both PCMs and has labeled them 0 and 1. However, when I upload our code to the roboRIO, and enable the robot, it says
Unhandled exception: edu.wpi.first.wpilibj.util.AllocationException: Solenoid channel 0 on module 1 is already allocated at [edu.wpi.first.wpilibj.Solenoid.initSolenoid(Soleno id.java:41)...
I have not allocated that channel anywhere in the code, and it gives the same error no matter what module ID I use or channel number.
Has anyone else had this same issue? Are the PCMs wired wrong? Thanks
Unread 25-02-2016, 15:42
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Code Not Recognizing Second PCM
We are succesfully using two PCMs, with Java.
If you keep reading through the trace-back from the exception, it will show what line of your code it thinks is re-allocating channel 0 on module 1. It's possible it's somewhere in your code that you forgot about.
Unread 26-02-2016, 13:56
alambert14's Avatar
Student Programmer
AKA: Abby Lambert
Rookie Year: 2014
We looked through all of our code and we are certain that it was not already allocated somewhere, especially since we had not previously had a second PCM ID in our RobotMap. In addition, it says that every single channel is already allocated.
Unread 26-02-2016, 17:06
Rookie Year: 1997
It's really hard to diagnose without the trace back and your code.
