Go to Post If the left side of your brain controls the right side of your body then left handers are the only ones in "their right mind". - Al Skierkiewicz [more]
Unread 25-02-2016, 17:37
yonip yonip is offline
FRC #0449 (The Blair Robot Project)
Rookie Year: 2014
yonip is an unknown quantity at this point
Changing Camera Aspect Ratio in Code
So we want cameras with high FOV so drivers can see, but the problem is that our 16:9 USB camera feed is truncated to 4:3. Is it at all possible to change the aspect ratio of the feed so that we can actually see the whole image from the stream?
Unread 26-02-2016, 08:07
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Changing Camera Aspect Ratio in Code
If you want fine tuned control of your camera you'll probably need to ditch USBCamera and write your own wrapper.
First, find all supported capture modes on your camera with IMAQdxEnumerateVideoModes(). Find the mode you want, and set it using IMAQdxSetAttribute() with IMAQdxAttributeVideoMode. Further IMAQdx documentation should be in C:\Program Files (x86)\National Instruments\Vision\Help
