Go to Post "But from a real life standpoint, that looks like something the evil villains in a superhero movie would use to get around in" Reading the phrases "real life" and "evil villains in a superhero movie" in the same sentence makes me giggle. - Alan Anderson [more]
Unread 27-02-2016, 14:14
TheMechanic40 TheMechanic40 is offline
FRC #3506 (YETI Robotics)
Rookie Year: 2013
TheMechanic40 is an unknown quantity at this point
Riolog not displaying output
Hi, we're using Java and we've been having problems using riolog. We had it working correctly last year, but it doesn't seem to want to work now. We're using Eclipse Mars and I made sure to check the console out option when we imaged the roborio at the beginning of build season. Does anyone know what could be happening? Is there some sort of bug with Mars, I remember it didn't like deploying to 2015 roborios so is it the same kind of thing here? We've resorted to using smart dashboard to display values which is fine, but it can be a little finicky so we'd like to use riolog for simple printing. Thanks!
Unread 27-02-2016, 14:31
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Re: Riolog not displaying output
Are you trying to use it over wireless? If so have you downloaded the 16.4 radio config update (from 2/11) and reconfigured your radio? That update fixed a bug with rioLog over wireless.
https://usfirst.collab.net/sf/frs/do...ation_utilit_0
