Go to Post Ya know...they created the "RUMOR MILL" for a reason. - Andy Grady [more]
Unread 27-02-2016, 18:54
vigneshv vigneshv is offline
FRC #2489
vigneshv is on a distinguished road
Versaplanetary 3:1 and others sold out
Hi,
Does anyone know where we could get 3:1 versaplanetary stages? They are sold out on VexPro until May, and are back ordered on West coast products. Does anyone have stages that we could buy/use (we work in San Jose, CA)?
Unread 27-02-2016, 19:03
Mike dennis's Avatar
Mike dennis Mike dennis is offline
SPAM (2009-2013)
FRC #1902 (Exploding Bacon)
Mike dennis is a jewel in the roughMike dennis is a jewel in the roughMike dennis is a jewel in the rough
Re: Versaplanetary 3:1 and others sold out
You should try The Robot Space. They are also out of 3:1, but have most of the others in stock. The Robot Space
Have you heard about Spark?
FRC-1902 Exploding Bacon
-(college student/mentor 2014-present)
FRC-180 S.P.A.M.
-(student 2009-2011)
-(college student/mentor 2012-2013)
Unread 27-02-2016, 19:09
FRC #2489
Thanks for the suggestion. The issue is that it's for our shooter, so an adjustment from 3:1 to 5:1 would give us problems with power for our shot.
Unread 27-02-2016, 20:06
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
Team Role: Leadership
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
What's your target RPM and what motor are you planning on using?
Unread 27-02-2016, 20:08
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
Rookie Year: 2013
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
What motors are you planning on using?
Unread 27-02-2016, 20:24
FRC #2489
We're using 775pro motors on our competition robot (which has 3:1 gearboxes) - these gearboxes will be for our practice robot (we were running those motors at 60% with the 3:1 gearboxes to get a long-distance shot).
Unread 27-02-2016, 20:33
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
You can get similar performance running a CIM or MiniCIM at a 1:1 ratio (the performance characteristics of a 775pro are almost identical to a CIM when geared to the same RPM). If you need to use the planetary for output shaft or mounting reasons, you could also just get a CIM Adapter for it. Since you're currently only planing on running the 775s at 60% you have a bit of margin to play with as far as RPM goes.
Just a suggestion.
Unread 27-02-2016, 20:41
dradel's Avatar
Rookie Year: 2013
If you have the versa output sections I would just put a a mini cim on it with the adaptor and run it 1:1
Unread 27-02-2016, 22:20
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
The VP uses mount holes on a 2" diameter circle. So does the CIM. This is not a coincidence, and the VP *can* be a drop-in replacement for a CIM and vice-versa.
As a result, you can use VEX's CIM-ile. It takes a 775PRO and gives it a spur gear reduction, and is a drop-in replacement for your VP's and CIM's. It gives you the output RPM of a CIM - slightly less than a 3:1 VP but definitely more than a 5:1 VP.
AndyMark sells a CIM-mounted encoder, if you need to replace the VP encoder.
We went to CIM-iles because one of our 3:1 reductions is a bit less efficient than the other, and we've stripped 2 of the VP 775 collars. These motors are so durn powerful...
GitHub
