Powered cart?
'Ello everyone. Im curious because I've found nothing about it in the rules, is it legal/ok to have a battery and a DC/AC converter on the robot's cart for charging laptops/phones etc? The cart battery would never be powering anything robot related other than the driver station.
Re: Powered cart?
it. Be careful with the output side of the inverter(120v bit), as especially being on a robot cart, it could easily be abraded, scrapped and even accidentally cut. You'll need to be super careful to make sure this can't happen. Something like this? http://www.chiefdelphi.com/forums/sh...ghlight=tablet Andymark sells an inverter with an SB50 Anderson already attached http://www.andymark.com/product-p/am-0626.htm Last edited by pilleya : 27-02-2016 at 19:54. |
Re: Powered cart?
Thanks for the quick reply and advice! Incidentally I have a converter I was going to use, and was going to buy one of these to connect it. http://www.amazon.com/NOCO-GC018-Soc...4M7 J8NTN6K16
Does it have to be an Anderson connector? Last edited by Daynater : 27-02-2016 at 20:06. |
Re: Powered cart?
We use older, more worn out batteries to run our inverter, not 'competition grade' ones but they all have common connectors and chargers. |
Re: Powered cart?
Thank you.
Re: Powered cart?
You probably want to be charge the battery with the same charger as you use for your other comp batteries. FIRST requires that all robot battery chargers have a SB50 connected, so yes I would suggest that you would need to put a SB50 connector onto the inverter cable I find it is relatively easy to crimp one of the SB-50 connectors on to 16awg, I did it for some battery chargers last season, if you don't have the crimping tool you can do it in a vice with a screwdriver and a hammer and then fill the lug up with solder( to strengthen and guarantee connection), as it is only a low current draw application |
