Go to Post Never should an idea be ridiculed, because ideas are exactly that just an idea. - Tim Delles [more]
Unread 27-02-2016, 22:56
Michael 4499 Michael 4499 is offline
FRC #4499 (The Highlanders)
Team Role: Leadership
Rookie Year: 2007
Michael 4499 is on a distinguished road
FRC Team 4499 Robot
Introducing team 4499's 2016 robot named Magnetar
Specifications
Drive Train
Vexpro two cim gearboxes
Overall gear reduction High:9.167:1 Low:20.833:1
Intake
Driven by a bag motor with a 25:1 gear down. Picture is not updated, there will be a 4" mecanum wheel on each side with two versawheels in the center.
Catapult
NOT SHOWN IN PICTURE
There is two 6 in. stroke and 1.5 in. bore pistons driving the catapult with a latch to pre-charge the system. There are two ballast tanks that are dedicated to fill the pistons.
Defenses that can be crossed
B and D defenses along with the low bar.
2016 Galileo & Carson - Gracious Professionalism
2016 Colorado - Chairman's award, Finalists
2016 Arizona North - Engineering Inspiration
Unread 27-02-2016, 23:14
mrnoble's Avatar
mrnoble mrnoble is online now
teacher/coach
FRC #1339 (Angelbotics)
Team Role: Coach
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Re: FRC Team 4499 Robot
Can't wait to play with you guys.
Remember why you're doing this.
Unread 27-02-2016, 23:17
Rookie Year: 2007
It is going to be a blast! See you in eleven days.
Unread 27-02-2016, 23:28
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
Mentor
FRC #4607 (C.I.S.)
Team Role: Coach
Rookie Year: 2012
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
that looks like it would be fun to drive... good luck this season!
"An error does not become a mistake until you refuse to correct it" ~JFK
Unread 27-02-2016, 23:30
Rookie Year: 2007
It is a lot of fun, 20 ft/s is really fast!
Unread 27-02-2016, 23:38
pilleya's Avatar
pilleya pilleya is online now
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
Team Role: Mechanical
Rookie Year: 2013
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
That is very fast!, does your robot get air(Dukes of Stronghold) when going over certain obstacles?
JVN Calc says that your low speed is about 7 ft/s
Which speed(high or low) are you using/planning to use the most?
Unread 27-02-2016, 23:42
Rookie Year: 2007
We definitely can get some air, but more than likely we will be using low gear to go over the defenses so it isn't so hard on the robot. We will use high gear to go through the low bar and secret passage.
