Go to Post Also, the judges don't give out awards for money. They give out awards for hard work and effort. - BigJ [more]
Unread 28-02-2016, 22:07
catacon catacon is offline
FRC #1444 (Lightning Lancers)
catacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to behold
FRC 1444 - 2016 Reveal
Hey all!
Here is FRC 1444 The Lightning Lancers 2016 robot. We had a great time making this robot with a relatively small team this year. We were able to get the robot running more than a week in advance which was a huge first for us; we even had time to scrimmage. This was also the first year we modeled over 90% of the bot.
  • Low and High goal capable with vision tracking
  • Low bar capable
  • Rock wall, rough terrain, and possibly moat capable
  • Boom is in the works for hanging, sally port, and draw bridge
We spent a good amount of time planning, shooting, and editing our reveal video this year. We hope you like it! See you in St. Louis!
https://www.youtube.com/watch?v=op7BxtqCwb8
Unread 28-02-2016, 22:28
Georges's Avatar
Georges Georges is offline
FRC #5479 (Café Bot)
Team Role: Leadership
Rookie Year: 2012
Georges is an unknown quantity at this point
Re: FRC 1444 - 2016 Reveal
Very impressed with your robot this year, guys. Can't wait to see it in person and play against and hopefully with you at STL!
Unread 29-02-2016, 00:20
Street_dreamZ Street_dreamZ is offline
Team Role: Team Spirit / Cheering
Rookie Year: 1000
Street_dreamZ is a splendid one to beholdStreet_dreamZ is a splendid one to beholdStreet_dreamZ is a splendid one to beholdStreet_dreamZ is a splendid one to beholdStreet_dreamZ is a splendid one to beholdStreet_dreamZ is a splendid one to behold
Looks great, love the shooter! It looks like it articulates to a fixed position, is that correct? How does that mechanism work? Also, it looks to me like your breaker isn't the most accessible, you might want to think of other places to put it in case the inspectors don't like it there.
I wish you the best of luck in building your climbing mechanism and the with the rest of the season!
Unread 29-02-2016, 04:45
Jaci's Avatar
Jaci Jaci is online now
AKA: Jaci R Brunning
FRC #5333 (Can't C# | OpenRIO)
Rookie Year: 2015
Jaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond repute
That is some nice looking vision tracking. Care to give any insight about it?
Jacinta R
Curtin FRC (5333+5663) : Mentor
5333 : Former [Captain | Programmer | Driver], Now Mentor
OpenRIO : Owner
Website | Twitter | Github
jaci.brunning@gmail.com
Unread 29-02-2016, 11:12
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
FRC Video Review - Change is Coming
FRC #4329 (Lutheran Roboteers)
Team Role: Coach
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Got to briefly see these guys running at 1706's field. A ton of power in their shooter! Looking forward to seeing you guys run at Chaifetz.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 29-02-2016, 18:11
Thanks!
The shooter does move to a fixed up position which can be adjusted between matches if necessary (I don't see us ever doing that, though). Basically, the shooter has two pieces that form a smooth, quarter-ring for the ball to roll on. The pivot motor for top of the shooter (with the wheels) is able to rotate 90 degrees in its mount. This rotation opens/closes the latch which allows the shooter to pivot up and down.
Here's a render of the mechanism: http://i.imgur.com/wV21jDP.jpg
We are using a PS3 Eye camera with a 12-RGBLED ring and running OpenCV on an ODROID. We do some thresholding to find green blobs and then look for corners. Since we know the dimensions of the target we can get the transform from the camera to the target using the eight corner points (highlighted in the video). We then find the angle (yaw) between a vector straight out of the shooter and a vector from the shooter center to the target center. The magnitude of the second vector is the distance to the target which also determines the shooter wheel speed.
The big tricks are setting the exposure correctly to minimize ambient light and finding the transform. Once you have the transform, you can do any sort of vector math you'd like to determine position on the field, etc.
