Go to Post I did research before asking a question on CD..blasphemous I know - rachelholladay [more]
Unread 29-02-2016, 08:55
sgeckler sgeckler is offline
Mentor - Team 4926
AKA: Sam Geckler
FRC #4926 (GalacTech)
sgeckler is an unknown quantity at this point
CIMcoder Help? Make the Red LED Go Away
Can someone point me to help for a CIMcoder? We've looked at Vex, AM, CRTE, check wiring setup etc. But we just have a LED on RED with no response. Best resource?
Unread 29-02-2016, 09:20
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
"Cool" Squad
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Rookie Year: 2014
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
Re: CIMcoder Help? Make the Red LED Go Away
If the LED is red on the encoder, that's good. If the LED's are red on the talon, that's bad. Which is it?
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
Unread 29-02-2016, 11:46
Mentor - Team 4926
AKA: Sam Geckler
The LED on the encoder is RED; that is good? Man I've really messed this up.
Unread 29-02-2016, 12:05
"Cool" Squad
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Rookie Year: 2014
If the LED on the encoder is red, that means it is working, which is good. If you are not getting a signal, check and make sure that the wires going into the breakout board are soldered correctly. If you still are not getting a signal, try adding pull-up resistors to the breakout board, that's what worked for us.
My FRC History:
