New radio question
We are having trouble with our new radio that was in the kit of parts. Are we required to use this radio or can we use last year's? Thanks in advance!
Re: New radio question
You have to use the radio included in this years kit of parts.
Thanks!
I have 3 of these new radios.
1. I had to turn off the wireless on my laptop I was using to flash them correctly. 2. I had to flash them to make them compatible with FRC fields (even if they may never see a field). 3. When I flashed the FRC firmware with success on each I accessed the configuration page and confirmed I got the FRC firmware (says FRC in the version). 4. I did not buy these from AndyMark I got mine from Amazon. 5. Crossover/straight through Ethernet cabling did not matter. 6. Use the Ethernet port with the 802.3 in the label. 7. I had no problem setting my team, WPA key or AP/Bridge/Frequency after I got this to work before that - I got success messages on the flash BUT the configuration would not take. |
Hey Fredi, what is the trouble that you guys are having?
Not sure I can have our guys contact you for specifics.... Thanks!
MY issues were fixed when i reflashed the firmware, then reset the WPA key.
I believe that is how we got ours to work again too.
Currently we're trying to use the new omp as a bridge and an old dlink modB as a 5ghz AP but for some reason they don't play nice. We used the configuration utility to flash both, the omp as a bridge and the dlink as an ap. We've done it before for two dlinks and it worked just fine, but not for the new router.
#10
